Michael,
Your instructions did not help... I'm sorry to be a bother about this, so, I'll restate the problem I'm having.
I have a Postgres database with a table called 'location', which consists of meteorological observation points with lat-long coordinates along with various other attributes:
CHARACTER|lid
CHARACTER|county
CHARACTER|coe
CHARACTER|cpm
CHARACTER|detail
DOUBLE PRECISION|elev
CHARACTER|hdatum
CHARACTER|hsa
CHARACTER|hu
DOUBLE PRECISION|lat
DOUBLE PRECISION|lon
CHARACTER|lremark
DATE|lrevise
CHARACTER|name
CHARACTER|network
CHARACTER|rb
CHARACTER|rfc
DATE|sbd
CHARACTER|sn
CHARACTER|state
CHARACTER|waro
CHARACTER|wfo
CHARACTER|wsfo
CHARACTER|type
CHARACTER|des
CHARACTER|det
INTEGER|post
CHARACTER|stntype
CHARACTER|tzone
Please notice that only one field is type integer, namely, the 'post' field; it is a boolean (1 or 0).
When I use the GRASS v.in.db command:
v.in.db driver=pg database=host=dell3-tir,dbname=hd_ob6tir table=location x=-1*lon y=lat z=elev key=1 where=rfc='OHRFC' output=locations
I am forced to supply key=???; the only thing that works for me is key=0 or key=1, etc. since I have no integer field with unique integer values. If I run v.in.db (above), I get:
GRASS_INFO_MESSAGE(19616,1): 5030 points written to vector
Building topology ...egistering lines: 1000 2000 3000 4000 5000
5030 primitives registered
Building areas:
0 areas built
0 isles built
Attaching islands:
Attaching centroids:
Topology was built.
Number of nodes : 4729
Number of primitives: 5030
Number of points : 5030
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
GRASS_INFO_MESSAGE(19616,2): Vector import complete
Which, I guess, looks OK. If I then use v.category:
v.category input=locations output=locations_new type=point,line,boundary,centroid,area option=add cat=1 layer=1 step=1
DBMI-Postgres driver error:
Cannot create index:
create unique index locations_new_1 on locations_new ( 1 )
ERROR: syntax error at or near "1" at character 56
GRASS_INFO_WARNING(19064,1): Cannot create index
0 new centroids placed in output map
Building areas:
0 areas built
0 isles built
Attaching islands:
Topology was built.
Number of lines : 0
Number of areas : 0
Number of isles : 0
Which has errors, and does nothing for solving my problem. If I use the GRASS query tool for the 'locations' or my newly created 'locations_new' vector maps, the x,y,z data is correct from v.in.db, but all the category data is the same, namely, for the first record of my Postgres table.
Consequently, trying to re-project the points into a LCC location using v.proj fails. Not to mention the fact that all the attribute data for my points in my lat-long location is useless because it's all the same.
How do I deal with this? Your help is appreciated.
Tom
Michael Barton wrote:
Thomas,
See below.
Michael
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
Date: Fri, 17 Mar 2006 12:37:20 -0500
To: Michael Barton <michael.barton@asu.edu>
Cc: Markus Neteler <neteler@itc.it>, grass developers list
<grass5@grass.itc.it>, Multiple recipients of list <grasslist@baylor.edu>
Subject: Re: [GRASS5] Built-in vector documentation extended
Michael,
This is very helpful and answers many questions I have about the new
vector format, especially points. I do want to confirm my understanding
from "Vector data processing in GRASS GIS" (please pardon my being
obtuse). SoÅ
In order to get a Postgres table consisting of point coordinates and
various attributes to import into my lat-long location using v.in.db, I
had to put a "1" in the field for the "category column name (string
required)"; when I put "lid" in the field, I got an error saying the
type was not an integer. It seems GRASS is expecting a string for the
field name that has integer as its type. My problem is that none of my
fields meet this requirement for the key field, the only column that
does, "lid", has type string.
The GRASS vector key field ("category") MUST be an integer. The matching key
field in your attribute table must also be integer to make a join.
Now, my question is, for 5030 records, how do I add an integer key
field? My guess is that I would have to write a script that (1) created
a new column (type integer) for the Postgres table and (2) looped,
sequentially filling the new field for each record with a unique integer
value ‹ or I could drop the table, and do all of this outside of the
Postgres/GRASS environment and reload the table. The problem I have with
doing either is that the table design is not my own and is controlled by
'outsiders'.
Use v.category to do this in GRASS.
Michael
Tom
Markus,
This is very helpful. It will make learning GRASS vector architecture much
easier for people.
Michael
phone: 480-965-6213
fax: 480-965-7671
Date: Thu, 16 Mar 2006 22:35:22 +0100
To: grass developers list <grass5@grass.itc.it>
Cc: GRASS user list <grasslist@baylor.edu>
Subject: [GRASS5] Built-in vector documentation extended
I have extended the vector overview document in
6.1-CVS, find also here:
http://grass.itc.it/grass61/manuals/html61_user/vectorintro.html
While it covers most modules, each now in a thematic
context, it may be fine tuned, improved.
Text pieces welcome (preferably CVS patches).
The idea is to give a short overview.
Currently the page is even W3 conformant
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams@noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
