[GRASS5] Code submission from SJ Geophysics
Timur,
(cc grass5)
thanks a lot for your contributions. Since we are ahead a feature
freeze I cannot promise to include them the next days (but maybe
some of your improvements). But later we can certainly add
changes of general interest, which, I am sure, you are contributing.
Your source code package I have stored here for the other developers:
http://mpa.itc.it/markus/tmp/SJGeo.txt
http://mpa.itc.it/markus/tmp/SJGeo.tar.gz
[Developers: we have to define an area where we will handle code
             submissions. Remember that we have more in the queue,
             posted recently]
Thanks again, Timur,
On Tue, Apr 23, 2002 at 03:29:37PM -0700, Timur wrote:
Markus,
Thanks for you interest to our work.
My name is Timur Kusherbaev,
I work for SJ Geophysics Ltd. (you communicate with Syd Visser several
days ago).
We use GRASS for geophysical data and I make needed programming to fit
it to our processing routine.
I send you file SJGeo.tar.gz with 4 programms:
1. r.recolor - this new program allows to make color management for
raster map using categories distribution in equal area mode and
generate desiring color levels using extended possibilities for linear
color interpolation or file color sets. The program works with FP maps
and has description (file DESCRIPTION in folder with program). This
program is very usefull to us because able to show maps with different
kinds of histograms. We hope it will be usefull to others.
2. s.out.ik - s.out.ik - Converts a GRASS site list file into an ASCII
file with coordinates and information for icons creation. This file can
be used directly by program v.in.poly for poligons (vector icons).
Program also has description. This program makes actions which can
seem similar to another programs but it use range of data to produce
icons and has some ways to regulate kind of icons.
3. d.site.labels - I made some changes (xoffset,yoffset,angle of labels
rotation) - all changes are in file CHANGES in directory.
4. r3.to.sites - I also add some possibilities to this program(to
output in certain range of values) and all changes also in file CHANGES
in directory of program.
Also some changes made with "r.digit" program which does not work
properly. But this changes not go to the way which was planed by
developpers: we only need to get ASCII file with digitized data. I cut
part of program which try to produce raster map and simly directed
output to ASCII file. That is enough to our purpuses but I am not shure
that it will be resonable to others.
We use "ps.map" to prepare scripts and I had to do some work around it.
It does not make boundary box (probably it is old) and when we try to
use it in Ghostscript we get message on this subject. So I added it and
removed from ps.map possibility to make automatic frame around output
because on the one side it is not usefull when we combine two or more
files to one script, and on the other side it is possible to add any
desiered frame from the mapping instructions. Also I included
possibility to rotate text. But I am not shure about all changes at
present because the program has a lot of modules and another parts which
can depend on changed ones. I did not study "ps.map" properly to be
shure that all changes are correct.
Timur
