On Monday, January 29, 2001, at 09:17 PM, Eric G . Miller wrote:
On Mon, Jan 29, 2001 at 07:05:01PM -0800, Jeshua Lacock wrote:
> Hi Eric,
> FYI, this snip from my config output seems odd to me:
> checking Tcl include dirs... -I/usr/local/include
> checking Tk include dirs... -I/usr/local/include
> checking Tcl/Tk library dirs... -L/usr/local/lib
> checking for Tk_MainWindow in -ltk8.0... no
> configure: warning: *** Failed to find Tcl/Tk libraries
> It finds the Tcl/Tk libs, but reports it doesn't.An unending burr in my britches...
I'm guessing you get that with a clean slate (i.e. does removing
config.cache and re-running ./configure make a difference) ?
Eric, yes, you are correct. Removing config.cache and re-running ./configure does not make a difference.
Probably another library is needed for 'ld' in the test script that is
generated. Is Tk tied into the native GUI on OS X? or is it tied to
XFree86? Could make a difference...Maybe:
$ ldd /usr/lib/libtk8.0.so
will tell you (won't work on ar archives [*.a]).
Mmm, I have a /usr/lib/libtk8.0.a, not /usr/lib/libtk8.0.so. And I do not have a "ldd" program. I tired:
$ ld /usr/lib/libtk8.0.a
And it reports: "ld: no object files loaded"
But as you pointed out, it won't work on archives.
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
