Recently I saw a discussion/post about how to create (and draw) new
icons on GRASS.
I have plans to use GRASS for ESI maps, but there is a problem: I need
to have ESI symbols (see link below for an example).
http://response.restoration.noaa.gov/type_subtopic_entry.php?RECORD_KEY(entry_subtopic_type)=entry_id,subtopic_id,type_id&entry_id(entry_subtopic_type)=312&subtopic_id(entry_subtopic_type)=5&type_id(entry_subtopic_type)=2<http://response.restoration.noaa.gov/type_subtopic_entry.php?RECORD_KEY(entry_subtopic_type)=entry_id,subtopic_id,type_id&entry_id(entry_subtopic_type)=312&subtopic_id(entry_subtopic_type)=5&type_id(entry_subtopic_type)=2
as a first stop, did you ask ESI if they will just give them to you?
email <orr.esi@noaa.gov>
If so, be sure to find out what rights you have to use and redistribute
them & their derivatives. If they exist as a font use d.text.freetype.
It would be really nice to have some simple parser to convert a .eps file
to a d.graph input file, have d.graph handle .eps internally, &/or a .eps
to grass symbol converter. (simple features only)
So, this icons are a little complex for drawing. Is possible to
include SVG icons (or any vector /bitmap format) on GRASS? (Note: I
know how to do this on QGIS).
You could get this PDF
http://response.restoration.noaa.gov/book_shelf/890_Key.pdf
Convert to PostScript and try extracting the coordinates.
Zooming in on them looks like they started out as vectors.
In a method mentioned by Paul some time ago, you could save a zoomed
version as a raster, load into GRASS in a XY location, run r.thin,
r.to.vect, v.clean, and 'v.out.ascii format=standard' to get the
resulting lines.
-or- if you can digitize them in QGIS, do so. Load into GRASS, use
v.transform to center them on 0,0 and scale appropriately, export lines
with 'v.out.ascii format=standard'.
Then edit that text file to add the symbol commands around the line
verticies.
It's work, but possible.
Hamish
