I have now merged the changes to the release branch into the head.
AFAICT, any file which exists in the release branch also exists in the
head, and both versions are identical (apart from differences due to
CVS keyword expansion, e.g. $Date, $Id, $Log etc).
OTOH, many files only exist in the head. Some of them should probably
be removed, while others should remain. In general:
1. Files which aren't currently being used, e.g. because of bugs, but
which might be used eventually should remain.
2. Files which have been made obsolete or which are otherwise unlikely
to ever be used should be removed.
Comments regarding which files fall into which category are
appreciated.
This sounds good.
Thanks for all the effort.
Glynn,
thanks a lot for your efforts!
Now is should be possible to build a working GRASS 5.1 as
all tools added to the exp are available again.
appreciated.
To start the cleanup: We need to categorize the code somehow.
With my scripts I can easily remove entire directories of
unwanted code, but that's probably not desired.
However, we have to achieve a code base with is understandable.
Does it make sense to maintain a file
CONTENTS
with a status comment for each module (=subdirectory)?
Then, probably I am missing something: Are the files which have
been deleted on release_branch also gone on exp? Or are they
mixed into the working code? Sorry for this naive question.
It appears that some have gone and some remain. I'm not sure what the
deciding factor is; I'm wondering if it has something to do with the
tag snafu that occurred last August. AFAICT, any files which were
removed from the release branch *should* have been removed by the
merge.
merge.
I've attached a list of files which have been added, removed, or not
removed by the merge.
(attachments)
changes.txt.gz (3.67 KB)
