Hi Martin,
to make it compile with my more restrictive compiler options,
I have to add to local_proto.h:
#include "symbol.h"
and
int test_bg_color (const char*);
and to include local_proto.h in area.c and plot1.c. Please
add this to your version.
I compile with
export CFLAGS="-g -Wall -Werror-implicit-function-declaration -fno-common"
./configure ...
to find such things (which are needed for portability).
So far I couldn't test yet, hopefully others will do.
On Sun, Jan 15, 2006 at 02:21:59PM +0100, Martin Landa wrote:
> Hi Markus,
> I think it should be more tested, the last think what I want is to make
> d.vect buggy (or more buggy;-). In the attachment you can find the
> last version of the patch
> (slightly modified version from 2005-11). So if you can, please test it.
> for grassdev list: This patch allows to display colored lines and
> points based on GRASSRGB column (not only areas).
> Best regards, Martin
> PS: Has anyone tested the similar patch for ps.map, see
> http://grass.fsv.cvut.cz/~martin/grass/patches/ps_map-grassrgb-2005-10-02.diff.gz
> 2006/1/12, Markus Neteler <neteler@itc.it>:
> > Hi Martin,
> > I lost track on this somehow, sorry. What do you think,
> > should I submit what I have from you to CVS?
> > Then you compare and, if needed, send final updates?
> > Markus
> > On Mon, Nov 07, 2005 at 09:56:11AM +0100, Martin Landa wrote:
> > > Hi Markus,
> > > 2005/10/28, Markus Neteler <neteler@itc.it>:
> > > > Testing the patch I got the idea that it may be useful/important
> > > > to exclude the color equal to the monitor background color to
> > > > avoid, that objects become invisible. This may be a simple if
> > > > statement using a function which fetches the current background
> > > > color.
> > > I am not sure if I understood well. Did you mean this??
> > > $ d.vect mapa col=white fcol=white
> > > WARNING: Line color and background color are the same!
> > > WARNING: Area fill color and background color are the same!
> > > or
> > > cat | grassrgb | vel
> > > 2 | 255:255:255 | 15
> > > $ d.vect mapa -a
> > > WARNING: Category <2>: Area fill color and background color are the same!
> > > WARNING: Category <2>: Line color and background color are the same!
> > > > While all types of vector are well displayed with color now
> > > > (no more error!), there is a small bug remaining:
> > > > #spearfish
> > > > d.vect fields disp=attr attrcol=label
> > > > should only display the labels (and also centroids?) but not
> > > > the areas. Hopefully also easy to fix...
> > > Yes, I am wondering if it is possible to determine correctly all isles by:
> > > /* initialize isles - needed? */
> > > isles = Vect_new_list ();
> > > for ( area = 1; area <= num; area++ ) {
> > > n_isles = Vect_get_area_num_isles ( Map, area );
> > > for ( i = 0; i < n_isles; i++) {
> > > isle = Vect_get_area_isle ( Map, area, i );
> > > if (isle > 0) {
> > > Vect_list_append (isles, isle);
> > > when I try to build topology of map 'fields' I see in report 11
> > > isles!! I don't know why so many isles...
> > > Number of areas : 65
> > > Number of isles : 11
> > > Number of areas without centroid : 2
> > > Attached patch for d.vect behaves in "old way":
> > > * area without centroid is not displayed (as "isle").
> > > I am not sure how to solve it better ... but hope it works now...
> > > Best regards,
> > > Martin
> > > > On Thu, Oct 27, 2005 at 06:36:06PM +0200, Martin Landa wrote:
> > > > > Hi Markus,
> > > > > there is the last patch for d.vect (against the current CVS). Sorry
> > > > > for this complication.
> > > > > 2005/10/27, Markus Neteler <neteler@itc.it>:
> > > > > > Hi Martin,
> > > > > > I have already deleted all patch files to reduce (my) confusion.
> > > > > > Can you send the changes again to me? For me it's best to only
> > > > > > have it against current CVS.
> > > > > > Thanks
> > > > > > Markus
> > > > > > Martin Landa wrote:
> > > > > > >Hi Markus,
> > > > > > >it is my fault, a little bit confusing I think, sorry for that:
> > > > > > >d_vect_rgb_column-2005-10-23.diff.gz is against the current CVS,
> > > > > > >please use this patch.
> > > > > > >area.diff is against d_vect_rgb_column-2005-10-18.diff
> > > > > > >Martin
> > > > > > >2005/10/26, Markus Neteler <neteler@itc.it>:
> > > > > > >>Martin,
> > > > > > >>the patch doesn't work, apparently it's not against the
> > > > > > >>current CVS?
> > > > > > >>patch -p0 < ~/area.diff
> > > > > > >>patching file d.vect/area.c
> > > > > > >>Hunk #1 succeeded at 44 with fuzz 2 (offset 24 lines).
> > > > > > >>Hunk #2 succeeded at 54 (offset -19 lines).
> > > > > > >>Hunk #3 succeeded at 173 with fuzz 2 (offset 24 lines).
> > > > > > >>Hunk #4 FAILED at 233.
> > > > > > >>Hunk #5 succeeded at 205 with fuzz 1 (offset -42 lines).
> > > > > > >>1 out of 5 hunks FAILED -- saving rejects to file d.vect/area.c.rej
> > > > > > >>Can you please recreate it against CVS?
> > > > > > >>Thanks
> > > > > > >> Markus
> > > > > > >>On Mon, Oct 24, 2005 at 12:27:12AM +0200, Martin Landa wrote:
> > > > > > >>>Hi,
> > > > > > >>>I have tried to solve this problem - I am really not sure, maybe I
> > > > > > >>>don't understand correctly areas and isles...
> > > > > > >>>There is a new patch for d.vect... I hope without any huge bugs;-)
> > > > > > >>>Please test it ... I am ready for your comments.
> > > > > > >>>Best regards,
> > > > > > >>>Martin
> > > > > > >>>2005/10/20, Markus Neteler <neteler@itc.it>:
> > > > > > >>>>On Tue, Oct 18, 2005 at 07:12:38PM +0200, Markus Neteler wrote:
> > > > > > >>>>>On Thu, Oct 06, 2005 at 09:18:33AM +0000, Martin Landa wrote:
> > > > > > >>>>>>Hi all,
> > > > > > >>>>>>I have rewritten the patch for d.vect which enables to use flags -a
> > > > > > >>>>>>and -c for all vector types (not only for areas). I hope I did it
> > > > > > >>>>>>better this time (for previous patch see
> > > > > > >>>>>>http://grass.itc.it/pipermail/grass5/2005-September/019563.html).
> > > > > > >>>>Hi Martin,
> > > > > > >>>>I tested the new d.vect code (the Vlib/area.c fix is in CVS),
> > > > > > >>>>but there is a bug in d.vect/area.c:
> > > > > > >>>>d.vect delauney
> > > > > > >>>>ERROR: Attempt to read topo for dead isle (2)
> > > > > > >>>>The problem is the line:
> > > > > > >>>> if (Vect_get_isle_area(Map, area))
> > > > > > >>>>Since this function ends with a fatal error for non-island
> > > > > > >>>>areas, it must be used in a different way.
> > > > > > >>>>However, for details better ask Radim...
> > > > > > >>>>I am sure that you'll iron out this missing piece!
> > > > > > >>>>Markus
> > > > > > >>>--- d.vect.18/area.c 2005-10-24 00:03:10.000000000 +0200
> > > > > > >>>+++ d.vect/area.c 2005-10-24 00:18:39.000000000 +0200
> > > > > > >>>@@ -20,8 +20,9 @@
> > > > > > >>> struct line_cats *Cats;
> > > > > > >>> int cat, centroid = 0;
> > > > > > >>> int red, grn, blu;
> > > > > > >>>+ struct ilist *isles = NULL;
> > > > > > >>>- struct field_info *fi=NULL;
> > > > > > >>>+ struct field_info *fi = NULL;
> > > > > > >>> dbDriver *driver = NULL;
> > > > > > >>> dbCatValArray cvarr;
> > > > > > >>> dbCatVal *cv_rgb = NULL;
> > > > > > >>>@@ -72,14 +73,26 @@
> > > > > > >>> num = Vect_get_num_areas(Map);
> > > > > > >>> G_debug (2, "n_areas = %d", num);
> > > > > > >>>+ /* initialize isles - needed? */
> > > > > > >>>+ isles = Vect_new_list ();
> > > > > > >>>+ for ( area = 1; area <= num; area++ ) {
> > > > > > >>>+ n_isles = Vect_get_area_num_isles ( Map, area );
> > > > > > >>>+ for ( i = 0; i < n_isles; i++) {
> > > > > > >>>+ isle = Vect_get_area_isle ( Map, area, i );
> > > > > > >>>+ if (isle > 0) {
> > > > > > >>>+ Vect_list_append (isles, isle);
> > > > > > >>> int i;
> > > > > > >>> BOUND_BOX box;
> > > > > > >>> G_debug (3, "area = %d", area);
> > > > > > >>>- if ( !Vect_area_alive (Map, area) ) continue;
> > > > > > >>>+ if ( !Vect_area_alive (Map, area) || Vect_val_in_list(isles, area)) continue;
> > > > > > >>> /* Check box */
> > > > > > >>> Vect_get_area_box (Map, area, &box);
> > > > > > >>> if ( box.N < window->south || box.S > window->north ||
> > > > > > >>>@@ -136,7 +149,7 @@
> > > > > > >>> Vect_append_points ( Points, IPoints, GV_FORWARD);
> > > > > > >>> Vect_append_point ( Points, xl, yl, 0.0 ); /* ??? */
> > > > > > >>> if( table_colors_flag ) {
> > > > > > >>> cat=Vect_get_area_cat ( Map, area , Clist -> field );
> > > > > > >>> centroid = Vect_get_area_centroid ( Map, area );
> > > > > > >>>@@ -196,20 +209,15 @@
> > > > > > >>> if ( fcolor > -1 ) {
> > > > > > >>>- if (Vect_get_isle_area (Map, area)) { /* isle ? */
> > > > > > >>>- R_RGB_color (255, 255, 255);
> > > > > > >>>+ if (!table_colors_flag && !cats_color_flag) {
> > > > > > >>>+ R_color(fcolor) ;
> > > > > > >>> else {
> > > > > > >>>- if (!table_colors_flag && !cats_color_flag) {
> > > > > > >>>- R_color(fcolor) ;
> > > > > > >>>+ if (rgb) {
> > > > > > >>>+ R_RGB_color ((unsigned char) red, (unsigned char) grn, (unsigned char) blu);
> > > > > > >>> else {
> > > > > > >>>- if (rgb) {
> > > > > > >>>- R_RGB_color ((unsigned char) red, (unsigned char) grn, (unsigned char) blu);
> > > > > > >>>- else {
> > > > > > >>> R_color (fcolor);
> > > > > > >>> G_plot_polygon ( Points->x, Points->y, Points->n_points);
> > > > > > >>>@@ -239,8 +247,10 @@
> > > > > > >>> } /* end for */
> > > > > > >>> Vect_destroy_line_struct (Points);
> > > > > > >>>+ Vect_destroy_line_struct (IPoints);
> > > > > > >>> Vect_destroy_cats_struct (Cats);
> > > > > > >>>+ Vect_destroy_list (isles);
> > > > > > >>> return 0;
> > > > > > >>Markus Neteler <neteler itc it> http://mpa.itc.it
> > > > > > >>ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
> > > > > > >>MPBA - Predictive Models for Biol. & Environ. Data Analysis
> > > > > > >>Via Sommarive, 18 - 38050 Povo (Trento), Italy
