http://mpa.itc.it/radim/g51/d.vect.chart_pie.png
http://mpa.itc.it/radim/g51/d.vect.chart_bar.png
Radim
Radim
On Fri, Apr 04, 2003 at 06:39:09PM +0200, Radim Blazek wrote:
Looks nice.
For piecharts I think we as sensible scientists
should print a warning to people that pies are not good to visualise
quantitative information. They are only good to hide information.
http://www.usf.uni-osnabrueck.de/~breiter/tools/piechart/warning.en.html
I've once wrote a little piechart program
and when I've dug into the literature for visualisation
I found out that piecharts are not a good idea.
Instead of scrapping my program I added the warning.
If people want to hide information, it might be useful. ;>
Professional Service for Free Software (intevation.net)
The FreeGIS Project (freegis.org)
FSF Europe (fsfeurope.org)
quantitative information. They are only good to hide information.Seite nicht erreichbar - Universität Osnabrück
I've once wrote a little piechart program and when I've dug into the
literature for visualisation I found out that piecharts are not a good
idea. Instead of scrapping my program I added the warning. If people want
This is probably worth mentioning in the related man page.
INVITATION:
In GRASS 5.1 each module contains (should, some are not written yet) a file
'description.html' which describes the module in the common way. The
parameters/flags part is generated on the fly and attached to this file.
We kindly invite contributors to write or develop the description.html
files for GRASS 5.1, you may use the existing 5.0 HTML files for that.
If you don't have CVS write access, just send the file to me (or Radim).
