Florian,
I had to make the following change to d.vect to get
it compiled on RH7/gcc 2.9x. It complained about the
position of the declaration.
Unfortunately d.vect no longer works on RHEL 3... Sigh.
d.vect help
Segmentation fault
GRASS 5.7.cvs:~ > gdb `which d.vect `
GNU gdb Red Hat Linux (6.1post-1.20040607.17rh)
(gdb) r help
Starting program: /hardmnt/thuille0/ssi/software/cvsgrass57/dist.i686-pc-linux-gnu/bin/d.vect help
Program received signal SIGSEGV, Segmentation fault.
0x00373049 in _int_free () from /lib/tls/libc.so.6
(gdb) bt
#0 0x00373049 in _int_free () from /lib/tls/libc.so.6
#1 0x00373794 in _int_realloc () from /lib/tls/libc.so.6
#2 0x00372136 in realloc () from /lib/tls/libc.so.6
#3 0x00279d0b in G_realloc (buf=0x92e86c8, n=412) at alloc.c:87
#4 0x0804c525 in icon_files () at main.c:83
#5 0x0804c727 in main (argc=2, argv=0xbfff8014) at main.c:167
nl main.c | head -110 | tail -3
82
83 closedir(dir_i);
84 closedir(dir);
I'm lost again...
On Wed, Dec 15, 2004 at 09:37:23AM +0100, grass@intevation.de wrote:
Author: markus
Update of /grassrepository/grass51/display/d.vect
In directory doto:/tmp/cvs-serv20407Modified Files:
main.c
Log Message:
fixed declaration position for gcc < 3.xIndex: main.c
RCS file: /grassrepository/grass51/display/d.vect/main.c,v
retrieving revision 1.45
retrieving revision 1.46
diff -u -d -r1.45 -r1.46
--- main.c 14 Dec 2004 20:43:40 -0000 1.45
+++ main.c 15 Dec 2004 08:37:21 -0000 1.46
@@ -57,6 +57,10 @@
for (;{ /*loop over each directory in etc/symbols*/
struct dirent *di = readdir(dir_i);
+ int ni = 0;
+ char *buf = NULL;
+ char *buf2 = NULL;
+ char *buf3 = NULL;if (!di)
break;
@@ -64,10 +68,6 @@
if (di->d_name[0] == '.')
continue;
- int ni = 0;
- char *buf = NULL;
- char *buf2 = NULL;
- char *buf3 = NULL;
ni = strlen(di->d_name);
buf = G_realloc(buf,(strlen(d->d_name) + ni + 1));
buf2 = G_realloc(buf2,strlen(d->d_name));
