[GRASS5] Darwin Pre2 Config Errors
On Friday, September 21, 2001, at 07:17 AM, Glynn Clements wrote:
checking for location of PNG includes... /usr/local/include
checking for png.h... yes
checking for location of PNG library... /usr/local/lib
checking for png_read_png in -lpng... no
configure: warning: *** Unable to locate PNG library.
I would need to see the config.log file to determine why this test
fails. I can't do anything without it.
Thanks for the help Glynn and Markus!
I'm sorry, my bad, the lib just need to be ranlib'ed...
checking for location of GD includes... /usr/local/include
checking for gd.h... yes
checking for location of GD library... /usr/local/lib
checking for gdImageCreate in -lgd... no
configure: warning: *** Unable to locate GD library.
GD often requires PNG, so this may just be a consequence of the PNG
failure.
It got further now that PNG works, but I am getting a "Undefined symbols: _gdImageGif.
Here is the relevant section from the confg.log:
configure:4759: checking for location of GD includes
configure:4791: checking for gd.h
configure:4801: gcc -E -traditional-cpp -I/usr/local/include conftest.c >/dev/null 2>conftest.out
configure:4833: checking for location of GD library
configure:4862: checking for gdImageCreate in -lgd
configure:4881: gcc -o conftest -O2 -mcpu=ppc conftest.c -lgd 1>&5
configure:5040: checking for gdImageGif
configure:5068: gcc -o conftest -O2 -mcpu=ppc -lgd conftest.c 1>&5
/usr/bin/ld: Undefined symbols:
_gdImageGif
Does gd need to be built with GIF support or something?
checking for gdImageGif... no
checking for gdImagePng... no
checking for location of Tcl/Tk includes... /usr/local/include/
checking for tcl.h... yes
checking for tk.h... no
configure: warning: *** Could not find 'tk.h'.
This one is really weird, it finds 'tcl.h' but not 'tk.h' located in the
same directory.
Odd. This check (AC_CHECK_HEADERS) involves attempting to pre-process
(via e.g. "cpp", "gcc -E" or similar) the following test program:
  #line 5436 "configure"
  #include "confdefs.h"
  #include <tk.h>
If the check fails, but tk.h is present, this implies that
pre-processing tk.h fails, e.g. because one of the headers which tk.h
includes can't be found.
My suspicion is that the X headers can't be found. I'll look into
adding the appropriate -I switch(es) automatically (via X_CFLAGS). If
I'm correct, you should be able to work around the problem using e.g.
  --with-tcltk-includes=/usr/X11R6/include
Note: this option accepts a space-separated list of directories, e.g.
  --with-tcltk-includes='/usr/local/include /usr/X11R6/include'
Yes, you are correct! Adding X11R6 to the tcltk includes fixed all the tcl/tk errors, thanks!
configure: warning: *** Tcl/Tk version mismatch.
Hmm, this one is new. I'm stumped.
This is an artifact of the tk.h test failing.
checking for location of Tcl/Tk libraries... /usr/local/lib
checking for Tcl_Init in -ltcl... yes
checking for Tk_MainWindow in -ltk... no
configure: warning: *** Unable to locate Tk library.
Possibly related to X libraries, although I would need to see
config.log to be sure.
You are correct, it's all fixed now, thanks again!
BTW: I have decided to skip the BLAS and LAPACK libraries for now
because they are Fortran. What module(s) use them?
I don't think that anything uses them at present.
OK, great thanks for the scoop..
Kind regards,
Jeshua Lacock http://OpenOSX.com
Programmer/Owner http://SierraMaps.com
Phone: (760) 935-4736 http://3dTopoMaps.com
> failure.
[snip]
Only one of these two functions needs to be found. If gdImageGif is
present but gdImagePng isn't, the PNG driver will actually create a
GIF image instead of PNG. If both are found, PNG is used.
Originally, only PNG was supported. I changed it because the GD
library which comes with RedHat 6.2 only supports GIF.
It's possible that your version of GD only supports PNG (hence the
gdImageGif test failing), but the gdImagePng test fails due to e.g.
PNG dependencies.
I would need to see the output from both tests to determine what's
actually wrong.
