[GRASS5] Darwin: unixODBC
Thanks in no small part to Mr. Nick Gorham (the co-author of unixODBC), I have built and installed unixODBC 2.0.7 here.
When I attempt to build the ODBC driver, I get the error "ld: can't locate file for: -lodbc".
What might the header look like for the ODBC entries?
Mine is:
ODBCINC = -I/usr/local/include
ODBCLIB = -L/usr/local/lib
I checked and those are indeed the correct locations that unixODBC was installed to.
Any ideas?
Here's the full message:
/usr/src/grass/src/libes/dbmi/drivers/odbc
   make -f OBJ.powerpc-apple-darwin1.3.3/make.rules
gcc -o /usr/src/grass/dist.powerpc-apple-darwin1.3.3/driver/odbc OBJ.powerpc-apple-darwin1.3.3/main.o OBJ.powerpc-apple-
darwin1.3.3/driver.o error.c OBJ.powerpc-apple-darwin1.3.3/listdb.o OBJ.powerpc-apple-darwin1.3.3/db.o OBJ.powerpc-apple-
darwin1.3.3/listtab.o OBJ.powerpc-apple-darwin1.3.3/connect.o OBJ.powerpc-apple-darwin1.3.3/describe.o OBJ.powerpc-apple-
darwin1.3.3/cursor.o OBJ.powerpc-apple-darwin1.3.3/select.o OBJ.powerpc-apple-darwin1.3.3/fetch.o OBJ.powerpc-apple-
darwin1.3.3/execute.o OBJ.powerpc-apple-darwin1.3.3/table.o /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.3.3/libdbmi.a ../LIB.powerpc-apple-darwin1.3.3/libstubs.a /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.3.3/libgis.a -I/unixODBC -I/usr/local/include -I/usr/src/grass/src/include -lodbc -I/usr/include -L/usr/local/lib -lz
/usr/bin/ld: can't locate file for: -lodbc
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
