[GRASS5] DataBase Drivers Missing !
  I'm running GRAS 5.3 on my DEBIAN. I installed from the binaries, and
now when I'm trying to use Postgres in conjuntion with GRASS, I realize
that there is not 'db' directory under the drivers directory (It exist
in GRASS 5.7.0, but probably due to the automatic installation is not in
GRASS 5). Is there any way to obtain only the code, and then to compile
and to install, only such drivers, or I need to download GRASS source
and compile all ?
  Thanks
   D
Stay ahead of the information curve.
Receive GIS news and jobs on your desktop daily.
Subscribe today to the GIS CafeNews newsletter.
[ http://www10.giscafe.com/nl/newsletter_subscribe.php ]
It's informative and essential.
and compile all ?
The use of databases for vector maps is new in 5.7.
5.3 only supports the use of databases for a few specific purposes,
primarily for storing category tables. And it only supports
PostgreSQL.
If you want to use vector databases, you have to use 5.7, not 5.3.
PostgreSQL.
Thanks Glynn for you advice.
I'm moving to GRASS 5.7 now... I tried to import the GRASS 5.3 vector
files, but I received this message :
v.convert input=Anantapur_NEW output=Anantapur_V57 endian=bigeading dig
file...
Input file is version 4.
Input file is portable.
0 points read to memory
0 lines read to memory
1 area boundaries read and written to output
0 dead points skipped
0 dead lines skipped
0 dead area boundaries skipped
0 elements of unknown type skipped
0 elements read to memory.
Reading dig_att file...
0 point categories read
0 line categories read
1 centroids read
0 dead point categories skipped
0 dead line categories skipped
0 dead centroids skipped
0 categories of unknown type skipped
1 categories read into memory.
Attaching categories... 100%
DBMI-Postgres driver error:
cannot get user/password
Writing new file...
0 points and lines written to output file.
1 centroids written to output file.
ERROR: Cannot open database $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
Could you explain me how to do it ?
Thanks
  D.
