[GRASS5] DB default settings now defined in new mapset
I have fixed the lack of default DBF DB settings when
creating a new mapset. Now both the text interface and the
GUI create the dbf/ directory in a newly created mapset
and copy over the VAR file from PERMANENT which contains
the default DB settings.
Fixed in both 6.0-CVS (for 6.0.2) and 6.1-CVS.
A user can certainly modify the settings with db.connect as
before.
On Tue, Oct 18, 2005 at 11:42:52AM +0200, Markus Neteler wrote:
Radim suggested to me that it is better to not copy the
PERMANENT/VAR settings, but to generate the VAR file
with DBF settings from scratch.
Unfortunately, I don't manage to program it:
In file lib/init/mke_mapset.c
/* generate DB settings file in new mapset */
        sprintf(buffer,"'%s'/'%s'/VAR", location, mapset);
        if ((fd = creat (buffer, O_RDWR)) < 0) {
                perror (buffer);
                G_fatal_error("Cannot create VAR file in new mapset");
        fprintf (fd, "DB_DRIVER: dbf\n");
        fprintf (fd, "DB_DATABASE: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/\n");
        fclose (fd);
mke_mapset.c: In function `make_mapset':
mke_mapset.c:33: warning: assignment makes pointer from integer without a cast
My usual string problems... Then it happily segfaults.
Any idea?
Hello Markus
               perror (buffer);
       fclose (fd);
Any idea?
I think creat() only returns a file descriptor. But fprintf and fclose have a stream as their first argument. So you need to call fdopen() to derive a stream from the file descriptor returned by creat. I think. But why not just do it all in one step with fopen() instead of creat(). I have never seen creat() used like that.
Also to be more buffer overflow-safe you could write
instead as
char *buffer;
G_asprintf(&buffer,"'%s'/'%s'/VAR", location, mapset);
/* do something with buffer */
G_free(buffer);
Hope this helps a little bit.
Paul
Hello Paul,
On Tue, Oct 18, 2005 at 04:07:56PM +0100, Paul Kelly wrote:
Hello Markus
> perror (buffer);
> fclose (fd);
>cast
>Any idea?
I was looking at lock.c in the same directory. Maybe it's wrong
as well?
instead as
char *buffer;
G_free(buffer);
Cool - I got it working.
Thanks for the quick help,
PS: Now I have to learn TCL to fix the GUI as well
as well?
I had a look and it uses write() instead of fprintf(). So that will work with creat(). I have no idea why it's written like that. Maybe faster.
Paul
Hi again,
update:
and generate a new VAR file which contains the default DB
settings to DBF.
Fixed again in both 6.0-CVS (for 6.0.2) and 6.1-CVS.
before.
cheers
settings to DBF.
before.
just as a historical note, the v.in.garmin script has a test & shell
code for this.
Hamish
