[GRASS5] Debian and d.m/d.zoom bug - /etc/ld.so.conf
from Paolo C. I got temporary access to a Debian box
to check the problem with d.zoom in the display manager.
The idea is to avoid the /etc/ld/so.conf hack which is
necessary to make d.m/d.zoom functional:
See:
http://grass.itc.it/pipermail/grassuser/2004-November/027112.html
First test:
echo $LD_LIBRARY_PATH
/usr/local/grass5.7.cvs-i686-pc-linux-gnu-25_11_2004/lib
...looks ok. Ans this directory contains the libs.
I found out so far:
- d.zoom on CMD line works;
- d.m/d.zoom (icon) fails: for microseconds the requested terminal
  is opened, then it closes. no error message.
Looking into the code, I found that in effect next line is executed
in the display manager:
xterm -e d.zoom
Running this command on command line provides the same undesired
behaviour (immediate closing of xterm after launching).
Interestingly, when running
strace xterm -e d.zoom
it works!
ldd `which strace`
        libc.so.6 => /lib/tls/libc.so.6 (0x41019000)
        /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x41000000)
doesn't report anything special,
nor:
ldd `which xterm`
        libXft.so.2 => /usr/lib/libXft.so.2 (0x415c0000)
        libfontconfig.so.1 => /usr/lib/libfontconfig.so.1 (0x416b2000)
        libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x41643000)
        libexpat.so.1 => /usr/lib/libexpat.so.1 (0x416db000)
        libXrender.so.1 => /usr/lib/libXrender.so.1 (0x415e9000)
        libXaw.so.7 => /usr/X11R6/lib/libXaw.so.7 (0x40014000)
        libXmu.so.6 => /usr/X11R6/lib/libXmu.so.6 (0x40071000)
        libXt.so.6 => /usr/X11R6/lib/libXt.so.6 (0x419ce000)
        libSM.so.6 => /usr/X11R6/lib/libSM.so.6 (0x41a3c000)
        libICE.so.6 => /usr/X11R6/lib/libICE.so.6 (0x41a23000)
        libXpm.so.4 => /usr/X11R6/lib/libXpm.so.4 (0x40088000)
        libXext.so.6 => /usr/X11R6/lib/libXext.so.6 (0x41633000)
        libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x414df000)
        libncurses.so.5 => /lib/libncurses.so.5 (0x40098000)
        libz.so.1 => /usr/lib/libz.so.1 (0x4161f000)
        libdl.so.2 => /lib/tls/libdl.so.2 (0x4117b000)
Any suggestions how to proceed? Maybe the xterm doesn't work as
desired under Debian (why does it then with strace)?
Hello Markus,
On Tue, 30 Nov 2004 18:12:33 +0100 Markus Neteler <neteler@itc.it>
Maybe it is a security reason, because xtrem has the s bit set. I am not
quite sure about that, but isnt it that $LD_LIBRARY_PATH is unloaded
for s-bittet programms?!
See former posting from Glynn Clements on a similar problem:
http://grass.itc.it/pipermail/grass5/2004-September/015409.html
Please correct me if I am wrong.
  Stephan
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
It seems a quite reasonable explanation.
Could anybody suggest a clean solution?
pc
At 07:57, mercoledì 01 dicembre 2004, Stephan Holl has probably written:
Hello Markus,
Stephan
Paolo Cavallini
cavallini@faunalia.it www.faunalia.it www.faunalia.com
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
iD8DBQFBrX2b/NedwLUzIr4RApV6AJ4lzpuUV97osdkNbPFwtCUL4MegYQCfcy7j
faAhcy0uTlY8YqB0zxv9710=
=6AT6
-----END PGP SIGNATURE-----
On Wed, Dec 01, 2004 at 07:57:10AM +0100, Stephan Holl wrote:
Hello Markus,
OK, now in CVS:
grass57/tools/grass-run.sh
Howver, the proposed xterm line causes problems:
can't read "env(GISBASE)": no such variable
Not sure how to implement it correctly:
diff -u -r1.27 d.m.tcl
--- d.m.tcl 14 Sep 2004 16:48:38 -0000 1.27
+++ d.m.tcl 1 Dec 2004 09:00:14 -0000
@@ -85,7 +85,7 @@
proc term {cmd args} {
- eval exec -- xterm -e $cmd $args &
+ eval exec -- xterm -e $env(GISBASE)/etc/grass-run.sh $cmd $args &
OK, now in CVS:
This should go elsewhere, e.g. lib/init. AIUI, the tools directory is
meant for things which aren't installed, e.g. tools for building or
maintaining GRASS rather than for using it.
BTW, we shouldn't need tools/getModtime any more; man/Makefile has
been fixed to use make's built in functionality instead.
@@ -85,7 +85,7 @@
Tcl doesn't have "global" variables like most languages. It has
"top-level" variables, but these aren't normally visible within
procedures. You need to use "global" to make it visible, i.e.:
      global env
> OK, now in CVS:
OK, moved to lib/init/.
Removed in CVS.
> @@ -85,7 +85,7 @@
      global env
Thanks.
d.m is now updated in CVS.
Debian users: please try again (don't forget to revert the /etc/ld.so.conf change
for testing, run ldconfig as well).
I had to modify lib/init/grass-run.sh to make it working for Fedora:
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:"$GISBASE/lib"
                 ^^^^^^^^^^^^^^^^^-added
Hopefully this problem is resolved now.
Well in general it looks like it should just be passing on the current LD_LIBRARY_PATH (whatever that contains). Would something like
exec xterm -e LD_LIBRARY_PATH=$env(LD_LIBRARY_PATH) d.zoom
(in the Tcl code) not work?
And there is also the problem (noted in Glynn's original e-mail) that e.g. LD_LIBRARY_PATH is called different things on different platforms, e.g. DYLD_LIBRARY_PATH on OS X. But this can be fixed by dynamically substituting the correct variable name in at compile-time like is done for lib/init/init.sh
Paul
>change
lib/init/init.sh
Paul
[isn't it easier to handle such necessary conditions in grass-run.sh
rather than messing up d.m.tcl? ]
Please submit further changes directly to CVS (I would like to
leave this problem to more skilled programmers than me :slight_smile:
Thanks
change
lib/init/init.sh
Paul
The thing is we are assuming LD_LIBRARY_PATH has been unset by the time grass-run.sh is run, and we need to set it again. So your change doesn't really make sense as on the systems that have the problem, $LD_LIBRARY_PATH will already be empty by that stage. I was thinking if we need to pass on an already existing LD_LIBRARY_PATH, it needs to be evaluated before xterm is run as that is what unsets it.
I'm not sure enough to make a change, just want to add to the discussion and have it documented!
Paul
>>>/etc/ld.so.conf
>>>change
>>lib/init/init.sh
>>Paul
I simply took the proposed suggestion to make things happen (it was
suggested month ago).
OK, so we both leave it to someone else :slight_smile:
>like exec xterm -e LD_LIBRARY_PATH=$env(LD_LIBRARY_PATH) d.zoom
if [ -z LD_LIBRARY_PATH ] ; then
    LD_LIBRARY_PATH="$GISBASE/lib"
else
    LD_LIBRARY_PATH="$LD_LIBRARY_PATH":"$GISBASE/lib"
fi
export LD_LIBRARY_PATH
q: should order be "$LD_LIBRARY_PATH":"$GISBASE/lib" or
   "$GISBASE/lib":"$LD_LIBRARY_PATH"?
Hamish
No. Neither Tcl's "exec" command nor xterm's -e switch use the shell,
so you can't use shell syntax. You could use e.g.
  exec xterm -e /bin/sh -c $command
but that creates problems of its own (e.g. if the ultimate command
includes arguments which need to be quoted to prevent shell
substitutions etc).
lib/init/init.sh
Yep.
> lib/init/init.sh
Yes. The LD_LIBRARY_PATH_VAR substitution should be performed on
grass-run.sh.
xterm isn't guaranteed to be setuid/setgid; it isn't on my system
(Gentoo). Consequently, you don't know whether LD_LIBRARY_PATH will
have been re-set in xterm.
Historically, it needed to be setuid root to set the ownership of the
pty and to update the utmp/wtmp files. Modern versions of glibc have a
setuid-root helper program (pt_chown) to deal with the pty ownership,
and the utempter library has a similar helper to deal with the
utmp/wtmp files.
Yes. One option would be to copy it to a separate variable, e.g.:
  set env(saved_lib_path) $env(LD_LIBRARY_PATH)
  exec xterm -e ...
and have grass-run.sh restore it from that. Although that requires the
Tcl/Tk code to know about the platform-specific variable names.
Another option would be to dump the entire environment to a file and
have grass-run.sh restore it.
  exec xterm -e ...
Well as I understand it everything else will be preserved: it is just LD_LIBRARY_PATH that is unset; is that right?
What about just setting another variable in Init.sh? After the correct LD_LIBRARY_PATH for the GRASS session has been determined and set,
copy it also to GRASS_LD_LIBRARY_PATH. That wouldn't be unset by xterm and
then it could be restored to LD_LIBRARY_PATH in the script. Although I
suppose if the user changed their LD_LIBRARY_PATH after starting the GRASS session something might be missing, but that would probably be quite unlikely.
Paul
> exec xterm -e ...
There are a couple of other LD_* variables which are unset, e.g.
LD_PRELOAD.
Agreed. Although this doesn't entirely solve the issue of
platform-specific variable names, it removes it from the Tcl/Tk code.
Although I
We don't need to support that. The user can always change
GRASS_LD_LIBRARY_PATH if they really need to.
