It seems odd I never had to do this before, but how do you
edit a vector file to remove small areas? I want to delete
all areas smaller than 80,000 sq meters.
And a related question, I have a contour file generated by
r.contour on a single category from a landcover map. But the
lines are all type line rather than type area. I know I can
use v.digit to go in and change each of them to area, but is
there a program to change all "lines" to "areas"?
Bill
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
subject 'unsubscribe grass5'
length: 1384
max: 0
