Anyone recognize this one:
truffula:~/grass5_dev/grass57_cvs/lib/rst/interp_float kirkw$ make
cc -dynamiclib -Wl,-flat_namespace,-U,_cuserid -compatibility_version 5.7 -current_version 5.7 -install_name /usr/local/grass-5.7.cvs/lib/libgrass_interpfl.dylib -o /Users/kirkw/grass5_dev/grass57_cvs/dist.powerpc-apple-darwin7.6.0/lib/libgrass_interpfl.5.7.cvs.dylib -L/usr/X11R6/lib -L/Users/kirkw/grass5_dev/grass57_cvs/dist.powerpc-apple-darwin7.6.0/lib -L/usr/local/pgsql/lib OBJ.powerpc-apple-darwin7.6.0/func2d.o OBJ.powerpc-apple-darwin7.6.0/input2d.o OBJ.powerpc-apple-darwin7.6.0/vinput2d.o OBJ.powerpc-apple-darwin7.6.0/interp2d.o OBJ.powerpc-apple-darwin7.6.0/output2d.o OBJ.powerpc-apple-darwin7.6.0/point2d.o OBJ.powerpc-apple-darwin7.6.0/secpar2d.o OBJ.powerpc-apple-darwin7.6.0/segmen2d.o OBJ.powerpc-apple-darwin7.6.0/write2d.o OBJ.powerpc-apple-darwin7.6.0/matrix.o OBJ.powerpc-apple-darwin7.6.0/minmax.o OBJ.powerpc-apple-darwin7.6.0/init2d.o OBJ.powerpc-apple-darwin7.6.0/ressegm2d.o OBJ.powerpc-apple-darwin7.6.0/resout2d.o -lgrass_gis -lgrass_datetime -lz -lgrass_vect -lgrass_dig2 -lgrass_dgl -lgrass_rtree -lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase -L/usr/local/lib -lgdal -lgeotiff -lgrass_bitmap -lgrass_qtree -lgrass_interpdata -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gmath -lfftw && ln -sf libgrass_interpfl.5.7.cvs.dylib /Users/kirkw/grass5_dev/grass57_cvs/dist.powerpc-apple-darwin7.6.0/lib/libgrass_interpfl.dylib
ld: Undefined symbols:
_Cats2
_Map2
_Pnts
_count
_driver2
_ff
_sql2
/usr/bin/libtool: internal link edit command failed
make: *** [/Users/kirkw/grass5_dev/grass57_cvs/dist.powerpc-apple-darwin7.6.0/lib/libgrass_interpfl.5.7.cvs.dylib] Error 1
Kirk
It's fixed, so please test it after updating lib/rst and vector/v.*.rst
trees. All external symbols in the rst library (undefined at compile
time) has been moved to the library from each rst module.
Thank you.
Huidae Cho
_Cats2
_Map2
_Pnts
_count
_driver2
_ff
_sql2
make: ***
Kirk
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
