GRASS_FAKE_START=1 GISBASE=... dist.i686-pc-cygwin/bin/r.digit
--html-description
ERROR: MAPSET fakestart not found.
r.digit does not call G_parser(), so it cannot generate usage. But it
fails with "Programmer error: no flags or options" error after
inserting G_parser() to make a usage file. "No flags or options" can
be intended by programmers, should it be something like fatal errors?
You mean above problem? No, that should not stop compilation.
On Wed, 3 Nov 2004 13:39:49 +0100, Markus Neteler <neteler@itc.it> wrote:
On Wed, Nov 03, 2004 at 01:26:05AM -0600, Huidae Cho wrote:
> Hi,
> I got the following error when making r.digit:
> --html-description
This error happens in several modules. Someone will have to debug
it and add further fakestart tricks into libgis.
In this case the line in main.c
polyfile = G_tempfile();
is the problem (the function needs to be extended as it was done
for e.g. G_gisinit().
To debug it, just set in a shell all the variables such as
I mean "do we need the 'Programmer error: no flags or options' error?"
If no options or flags are defined, it is intended by developers, so
the module should continue instead of exit even if G_parser() is
called to generate usage..
