[GRASS5] Files for subpackages
Hello everybody!
The last days I tried to build a RPM-package of Grass5. The aim was
to have three subpackages with respectivly NVIZ, postgreSQL and the
ODBC part of GRASS. When I wanted to specify the files of these
subpackages I was a little bit confused. I'd like to explain why:
Concerning the installed files it doesn't make any difference if
NVIZ or ODBC are included. Otherwise I think that at least the
ODBC-driver or nvwish should be installed as they are build by
gmake5.
Can somebody explain me this effect?
Thank you in advance
Silke
Intevation GmbH http://www.intevation.de
subject 'unsubscribe grass5'
Hi Silke,
On Tue, Apr 03, 2001 at 02:09:32PM +0200, Silke Reimer wrote:
Hello everybody!
gmake5.
actually I don't see the problem... What is the idea of separation?
Generally: The basic package should have NVIZ compiled *without*
PostgreSQL support, an additional NVIZ package *with* PostgreSQL support
would be fine (to overwrite the other version). The ODBC doesn't hurt
at all (I think so).
Does this help?
Hi Markus,
many thanks for your answer. But I still have some questions (see
below).
On Fri, Apr 06, 2001 at 04:26:42PM +0100, Markus Neteler wrote:
Hi Silke,
> Hello everybody!
> gmake5.
Does this help?
Not really. Our idea was to have one subpackage with those parts of
grass which use OpenGL (which is NVIZ), another one for PostgreSQL
and a third one for ODBC. As I understand you a subpackage for NVIZ is
not possible/desired. Why not? In my opinion it shouldn't be a
problem because NVIZ is build separatly by gmake5 and linked to
grass5 afterwards.
Second: Can you give me the reason why the ODBC doesn't hurt at all?
My initial problem still exists. I think I should explain it again
because my first explanation wasn't really precise. The problem is
that the list of files before the building and installation of NVIZ
doesn't differ to that afterwards. I solved the problem by looking
for those files which are build by gmake5 in the NVIZ-directory
and the NVIZ-documentation files. But I still think that it is curios
that a difference doesn't exist.
Many greetings
Silke
Intevation GmbH (http://www.intevation.de)
On Mon, Apr 09, 2001 at 01:48:19PM +0200, Silke Reimer wrote:
Hi Markus,
below).
> Hi Silke,
> > Hello everybody!
> > gmake5.
> Does this help?
grass5 afterwards.
Mhhh: I have written:
this are two packages. The difference is: I would package NVIZ separately
from GRASS to save space. As far as I understand you want to or three full
GRASS packages. That's also possible... :slight_smile:
ODBC is not supported in NVIZ. The other modules which support ODBC
and other DBMS should always go into GRASS. So it doesn't hurt if it
is always included.
Perhaps we should phone? Maybe that's easier...
