[GRASS5] GRASS 5.0.0stable to be released soonish
On Mon, Jun 17, 2002 at 02:19:45AM +0100, Glynn Clements wrote:
I've merged most of the recent changes into the release branch. A
summary of the outstanding differences follows.
The outstanding differences fall into two categories:
1. Substantial changes to individual modules; for these, I'd just like
confirmation that the result is stable enough for inclusion in the
pre5 release.
2. I18N-related changes to key components (GRASS startup, libgis,
tcltkgrass). For these, I would really like confirmation that building
without NLS (i.e. no "--with-nls" option) has been tested by as many
people as possible.
If any portability issues (e.g. assumptions regarding bash, GNU make,
Tcl/Tk version, head.<arch> settings etc) have slipped in, the result
could be completely unusable for some users.
I'm not concerned about it breaking if --with-nls is used; this *will*
fail on systems where dgettext() etc are in libintl rather than in
libc (e.g. Cygwin).
[Lines beginning with "+" indicate added files or directories; the
rest are changed files.]
tcltkgrass I18N (alex)
+ locale/ru/tcltkgrass/
  locale/Gmakefile
  src/tcltkgrass/tcltkgrass
  src/tcltkgrass/main/gis_set.tcl
libgis I18N (alex)
+ locale/ru/LC_MESSAGES/libgis.po
  src/libes/gis/Gmakefile
  src/libes/gis/*.c
Startup I18N (alex)
+ locale/ru/grass_intro.txt
+ locale/ru/license.txt
+ src/general/init/license.txt
  locale/Gmakefile
  src/general/init/Gmakefile
  src/general/init/init.sh
d.text.freetype update (cho): alignment, rotation, command mode
+ src/display/d.text.freetype/vflib/
+ src/display/d.text.freetype/test.input
  html/html/d.text.freetype.html
  src/display/d.text.freetype/Gmakefile
  src/display/d.text.freetype/freetypecap
  src/display/d.text.freetype/main.c
d.vect.pg update (alex): -e flag [*]
  html/html/d.vect.pg.html
  locale/ru/LC_MESSAGES/d.vect.pg.po
  src.garden/grass.postgresql/d.vect.pg/dbvect.h
  src.garden/grass.postgresql/d.vect.pg/getAllOpts.c
  src.garden/grass.postgresql/d.vect.pg/getSopts.c
  src.garden/grass.postgresql/d.vect.pg/main.c
  src.garden/grass.postgresql/d.vect.pg/runInfxFile.c
v.to.pg update (alex): -p flag (PostGIS)
  locale/ru/LC_MESSAGES/v.to.pg.po
  src.garden/grass.postgresql/v.to.pg/dbvect.h
  src.garden/grass.postgresql/v.to.pg/getAllOpts.c
  src.garden/grass.postgresql/v.to.pg/getSopts.c
  src.garden/grass.postgresql/v.to.pg/main.c
  src.garden/grass.postgresql/v.to.pg/plotCat.c
  src.garden/grass.postgresql/v.to.pg/runInfxFile.c
v.in.shape update (david)
  html/html/v.in.shape.html
  src/tcltkgrass/module/v.in.shape
  src/mapdev/v.in.shape/basename.c
  src/mapdev/v.in.shape/lines.c
  src/mapdev/v.in.shape/main.c
  src/mapdev/v.in.shape/polygon.c
  src/mapdev/v.in.shape/vmap_import.c
This v.in.shape fix I suggest to include since David was categorizing
it as important bugfix.
pre5 release.
Glynn,
These changes are important. The bugs affected a lot of maps (though only 'dirty ones' ). The result is now final, unless further RC bugs appear.
David
> pre5 release.
The updated v.in.shape has been committed to the release branch.
So let's release pre5?
Markus?
Markus?
I am ready to go. Further objections?
Not from me.
> Markus?
Folks,
now GRASS 5.0.0pre5 is tagged:
release_25_06_2002_grass5_0_0_pre5
The source code package is uploaded to
http://grass.itc.it/grass5/source/
On Wed, Jun 19, 2002 at 06:31:03PM +0100, Glynn Clements wrote:
The actual source distribution needs at least minimal
testing: configure (with default settings), compile, install, startup,
run a couple of commands.
... volunteers welcome as usual.
Thanks to all contributors. Now we really have to get a auto-build
script working for the binary releases. Andreas, may I ask you to
send what you already have?
I just compiled pre5.0 with
./configure --with-tcltk-includes=/usr/include/tcl8.3 --with-postgres-includes="
/usr/include/postgresql /usr/include/postgresql/internal" --with-freetype --with
-dbm --with-freetype-includes=/usr/include/freetype2 --with-readline
And everything seems to work perfectly up to now.
I'll do my best to find bugs :wink:
Congratulations !!
Moritz
On Tue, Jun 25, 2002 at 06:10:14PM +0200, Markus Neteler wrote:
Folks,
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
