On Tuesday, February 5, 2002, at 03:52 AM, Glynn Clements wrote:
Jeshua Lacock wrote:
BTW: This build is 122 MB again, I cannot seem to make it smaller, the
Pre 2 binaries are 50 MB...Try "make strip". The binaries are no longer stripped automatically.
I tried your suggestion, I issued a "make strip" followed by a "make
bindist" and the resulting file is the same size."make strip" strips the files in dist.<arch>, but "make bindist" uses
the files from the installation directory. You would need to re-run
"make install" in between the two.
OK.
Thanks Glynn. That did the trick.
I am reloading the striped binaries now. The new binary archive is named the same as the last file upload with a ".S" extension.
Jeshua Lacock __________________________
Programmer/Owner Phone: 760.935.4736
http://OpenOSX.com Fax: 760.935.4845
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
