> I have hit a bug in GRASS 5.3--the first I've run into in a couple
> months of pretty solid work with this version.
> When trying to import a simple text file into the sites format, I
> get an error if the file contains non-numeric strings. Here is the
> file I was trying to import
> 501175.0877193,3836254.44444444,1968,room
> 502782.10526316,3839709.53216374,1915,room
> 502621.40350877,3842789.64912281,1889,room
> 503183.85964912,3844798.42105263,1874,room
> 501175.0877193,3842602.16374269,1894,roomblock
> 506505.02923977,3837566.84210526,1941,roomblock
> s.in.ascii sites=clearcreek_sites input=clearcreek_sites.txt fs=,
I can import that file without any problem.
GRASS53: > s.in.ascii in=barton_test.txt sites=barton_test fs=,
result:
name|barton_test
desc|s.in.ascii sites=barton_test input=barton_test.txt fs=
501175.0877193|3836254.44444444|#1 %1968 @room
502782.10526316|3839709.53216374|#2 %1915 @room
502621.40350877|3842789.64912281|#3 %1889 @room
503183.85964912|3844798.42105263|#4 %1874 @room
501175.0877193|3842602.16374269|#5 %1894 @roomblock
506505.02923977|3837566.84210526|#6 %1941 @roomblock
[Note you can just create ascii files with the correct format and put
them in the $MAPSET/site_lists/ directory as a last resort..]
I see the "desc|... fs=" has lost its "," .. need to fix that.
> It doesn't matter whether or not I put quotes around the character
> strings. The error I get is:
> *** malloc[14292]: error for object 0x357b: Pointer being
> reallocated was not allocated
> ERROR: G_realloc: out of memory
> If I get rid of the string fields (i.e., 'room' and 'roomblock'), it
> imports just fine.
Can you make this fail with a clean & up to date install of GRASS
5.0, 5.3, and 5.7? All have different versions now (as of today).
> I'd SWEAR this was working just fine in a previous version of
> s.in.ascii I was using last November. I didn't notice anything had
> been changed in the CVS for s.in.ascii in the past few months so I
> don't understand why this WAS working but isn't now.
Can you reproduce it on another computer? Is it only on 5.7?
One possibility is changes to src/libes/gis/sites.c.
The 5.0/5.3 version hasn't been touched in 22 months.
The 5.7 version had a change to a memory call 2 months ago.. -> !!??
see grass51/lib/sites/sites.c G_sites_close()
Another possibility is that the bug has always been present, but you
haven't been bitten by it before; bugs relating to malloc()ed memory
are often like that.
Upon doing some updates to s.in.ascii yesterday (see below) I came
across something, but didn't figure it out fully. It's a bit of a grey
area but I think it fails in a bad way (assigning data to sites which
don't have any). It isn't seen with uniform data coverage, which is the
usual case.
Take this input file:
2649375 6503980
2682513 5996973 5
2473745 5735185
2308057 5483339 text
2155623 5413749
2496942 6036738 2 word
2609610 6235565
2649375 6503980 two text
2682513 5996973
2473745 5735185 2.34 5.67
2308057 5483339
2155623 5413749
s.in.ascii produces:
name|test
desc|s.in.ascii sites=test fs=space
2649375|6503980|#1
2682513|5996973|#2 %5
2473745|5735185|#3 %5
2308057|5483339|#4 %5 @text
2155623|5413749|#5 %5 @text
2496942|6036738|#6 %2 @word
2609610|6235565|#7 %2 @word
2649375|6503980|#8 %2 @two @text
2682513|5996973|#9 %2 @two @text
2473745|5735185|#10 %2.34 %5.67 @two @text
2308057|5483339|#11 %2.34 %5.67 @two @text
2155623|5413749|#12 %2.34 %5.67 @two @text
From memory this is a long standing problem. As it can assign data
values to sites which don't have them, I'd throw this in the "bad" bug
box as it will silently give you the wrong answer.
In the past I've used @" " as placeholders for no-data records to get
around this. Note that most site modules will be confused by mixed
records like these; really I guess they should check against the "form"
header field but nothing does.
get_site.c only calls G_site_new_struct() once, after that the structure
is never freed or blanked, just overwritten. Thus site->dbl_alloc and
site->str_alloc go up but never down. Maybe ok (or even desirable) for
this to happen, but the values should be reset to NaN's or blank spaces
at least.
I tried freeing it in main.c after G_site_put_new() is called, and
having get_site() call G_site_new_struct() each time it is run, but that
lead to a segfault when a string att was used. Also tried a few other
things but no luck -- but I'm not very good with memory issues so the
problem isn't necessarily a difficult one. Maybe someone else can see
it more clearly.
Updates (I'll add to 5.7 in the next day or so):
* s.in.ascii should now deal with Mac OS9 and DOS text files without
cryptic error messages. Mac OS9 files are rejected while DOS files are
recovered with a warning message.
* now you can feed it x,y positions without a label or numeric attribute
and it will still work. (bug #1721)
Please test!!
Hamish
