[GRASS5] grass 6.1CVS: crashes with adapted sites library
Hi everyone,
I have trouble using modules that are not fully updated to
the new vect API and make use of the "adapted sites library" instead.
E.g., I am getting a segmentation fault from r.cost and r.drain:
r.drain in=cost out=routes vector_points=tmp,tmp2
WARNING: Adapted sites library used for vector points (module should be
         updated to GRASS 6 vector library).
[1]- Exit 255 v.net
Segmentation fault
The vector points are really ok: level 2 and a dbf-connection.
map 'tmp' has just 1 point, 'tmp2' has 7. Also, the curious
thing is that the modules crash before they do anything except
opening the maps. I know this because I will get a crash, even
if I supply an invalid map ('vector_points=tmp,doesnotexist').
So no actual processing seems to take place. It really crashes
at the very first occasion ...
Tried this on two different systems, one with a CVS version from
about a week ago and one from today.
Did anyone experience the same problems?
Thanks for any help!
Benjamin
