[GRASS5] GRASS compilation on cygwin and IRIX
i recompiled the latest CVS code on IRIX 6.5 with gcc 3.0 and on cygwin
(latest setup on W2K).
On IRIX i have to manually set all include/library dirs or the libraries
are not found. libpng and libgd are not found, although specified with
--with-png-libs=/usr/freeware/lib32 \
--with-png-includes=/usr/freeware/include \
--with-gd-libs=/usr/freeware/lib32 \
--with-gd-includes=/usr/freeware/include \
libs are there (double checked that).
If i put -lpng -lm to the header file, r.in.png and r.out.png compile.
But the PNGdriver does not compile at all:
SRC = /disk2/opt/grass/grass/src
  CMD = /disk2/opt/grass/grass/src/CMD
  UNUSED = /disk2/opt/grass/grass/unused
  HEADER = head.mips-sgi-irix6.5
  ARCH = mips-sgi-irix6.5
  GISBASE = /disk2/opt/grass/grass/dist.mips-sgi-irix6.5
  VERSION = 5.0.0pre2 August 2001
/disk2/opt/grass/grass/src/display/devices/PNGdriver
  make -f OBJ.mips-sgi-irix6.5/make.rules
gcc -g -O2 -I/disk2/opt/grass/grass/src/include -I../lib -c Color.c -o
OBJ.mips-sgi-irix6.5/Color.o
In file included from Color.c:9:
png.h:23:3: #error Neither PNG nor GIF supported
make: *** [OBJ.mips-sgi-irix6.5/Color.o] Error 1
Please see at:
http://members.tripod.de/AndreasLange/igrass/index.html
You should just be able to use
  --with-libs=/usr/freeware/lib32 \
  --with-includes=/usr/freeware/include \
PNGdriver needs the GD library; and it has to be found by configure.
Check config.log for the actual error messages produced by the tests.
Hi Glynn,
thanks for your comments.
I'll check this another time.
Problem is on cygwin:
my configure line:
./configure --prefix=$INST --with-postgres-root=/usr \
--with-postgres-includes=/usr/include/postgresql \
--with-postgres-libs=/usr/lib \
--x-includes=/usr/X11R6/include \
--x-libraries=/usr/X11R6/lib \
--with-tcltk-libs=/usr/local/lib \
--with-tcltk-includes=/usr/local/include \
--with-gd-libs=/usr/local/lib \
--with-gd-includes=/usr/local/include \
--with-png-libs=/lib \
--with-png-includes=/usr/local/include
sinppet from config.log:
configure:4546: checking for location of PNG includes
configure:4578: checking for png.h
configure:4588: gcc -E -I/usr/local/include conftest.c >/dev/null
2>conftest.out
configure:4618: checking for location of PNG library
configure:4647: checking for png_read_png in -lpng
configure:4666: gcc -o conftest -g -O2 conftest.c -lpng -lz 1>&5
configure:4696: checking for location of GD includes
configure:4728: checking for gd.h
configure:4738: gcc -E -I/usr/local/include conftest.c >/dev/null
2>conftest.out
configure:4768: checking for location of GD library
configure:4797: checking for gdImageCreate in -lgd
configure:4816: gcc -o conftest -g -O2 conftest.c -lgd 1>&5
configure:4889: checking for gdImageGif
configure:4917: gcc -o conftest -g -O2 -lgd conftest.c 1>&5
/cygdrive/c/DOKUME~1/ADMINI~1/LOKALE~1/Temp/ccgn0CNd.o: In function
`main':
/home/Administrator/cygwin/extra/grass-5/tmp/grass/configure:4911:
undefined reference to `gdImageGif'
collect2: ld returned 1 exit status
configure: failed program was:
#line 4894 "configure"
#include "confdefs.h"
/* System header to define __stub macros and hopefully few prototypes,
    which can conflict with char gdImageGif(); below. */
#include <assert.h>
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
    builtin and then its argument prototype would still apply. */
char gdImageGif();
int main() {
/* The GNU C library defines this for functions which it implements
    to always fail with ENOSYS. Some functions are actually named
    something starting with __ and the normal name is an alias. */
#if defined (__stub_gdImageGif) || defined (__stub___gdImageGif)
choke me
#else
gdImageGif();
#endif
; return 0; }
configure:4889: checking for gdImagePng
/cygdrive/c/DOKUME~1/ADMINI~1/LOKALE~1/Temp/ccqOKwxV.o: In function
`main':
undefined reference to `gdImagePng'
    which can conflict with char gdImagePng(); below. */
#include <assert.h>
char gdImagePng();
int main() {
#if defined (__stub_gdImagePng) || defined (__stub___gdImagePng)
choke me
#else
gdImagePng();
#endif
First, why is gdImageGif checked? GIF support was officially dropped in
gd some time ago.
The gdImagePng(); test fails, even if i manually compile a test program.
But the test programs from gd-1.8.4 all compile. I have at the moment no
time to investigate further.
Now i re-run configure on Linux and the gd library is not found, too:
configure:4783: checking for gd.h
configure:4793: gcc -E -I/usr/local/include conftest.c >/dev/null
2>conftest.ou
t
configure:4823: checking for location of GD library
configure:4852: checking for gdImageCreate in -lgd
configure:4871: gcc -o conftest -g -O2 conftest.c -lgd 1>&5
/usr/lib/gcc-lib/i686-redhat-linux/2.96/../../../libgd.so: undefined
reference t
o `uncompress'
reference t
o `sqrt'
reference t
o `jpeg_read_scanlines'
reference t
o `jpeg_simple_progression'
reference t
o `png_get_rowbytes'
reference t
o `png_set_strip_16'
reference t
o `floor'
reference t
o `png_create_read_struct'
reference t
my configure line:
Note: don't specify any directories in which the preprocessor/linker
will look automatically.
I wouldn't have thought it necessary to specify anything other than:
The X directories should be determined automatically, and the rest
should be searched automatically.
2>conftest.out
This indicates that png.h is found.
This indicates that libpng is found (and contains png_read_png).
2>conftest.out
This indicates that gd.h is found.
This indicates that libgd is found (and contains gdImageCreate).
`main':
[snip]
But it doesn't contain gdImageGif ...
`main':
[snip]
... or gdImagePng. So what formats does it support?
gd some time ago.
GRASS doesn't support GIF, but GD does. Some versions (e.g. the one
which came with RedHat 6.2) only support GIF. As the only differences
to PNGdriver are:
a) whether to call the output file "map.gif" or "map.png",
b) whether to call gdImageGif or gdImagePng in Graph_Close,
I figured that it was worth supporting GD libraries without PNG
support.
gdImageGif writes "non-LZW" GIFs. The data stream is still valid to
the LZW decompressor, but the compressor uses a degenerate encoding
that eliminates the use of the technique which is covered by the
UniSys patent.
2>conftest.out
[snip]
Note that GD is tested twice, once without $PNGLIB, and once with. If
your libgd is linked against libpng (and doesn't have dependency
information), the first test will fail. The above is the first test
failing. It's the second test which is relevant.
Hi Glynn, Hi all,
thanks Glynn for your patience and time.
> my configure line:
Yes you are right, this was from the previous versions where configure
was not able to find the libaries.
> 2>conftest.out
> 2>conftest.out
> `main':
[snip]
> `main':
[snip]
> gd some time ago.
to PNGdriver are:
support.
UniSys patent.
Problem is that the official version of gd from boutell.com does not
support gif. But there are different patched versions out on the net
which support gif (without lzw compression) and gif (with lzw
compression). The UniSys patent is IMHO not applicable for some
countries. So some people prefer the lzw-gif version over the non-gif
png version.
> 2>conftest.out
[snip]
On my Linux system (Red Hat 7 based) i have installed the latest gd
(1.8.4) version. This is linked against jpeg. So the second test does
fail too.
This is the reason that libgd is _not_ found by configure. There should
be an additional test with $JPEGLIB added.
For unknown reasons the gd lib on cygwin seems to be broken.
This snippet:
#include "gd.h"
#include "png.h"
int main() {
gdImagePtr im;
FILE *out;
(void) gdImagePng(im, out);
compiles on my linux box only with:
gcc -lgd -lpng -ljpeg test-gd.c
on cygwin:
$ gcc -L/usr/local/lib -lgd -lpng -ljpeg -lz test-gd.c
/cygdrive/c/DOKUME~1/ADMINI~1/LOKALE~1/Temp/ccIa0X86.o(.text+0x17):test-gd.c:
(same with re-ordering of libraries, adding -lz etc, other paths etc.)
But with the latest CVS updates there are more problems on cygwin:
$ cat error.log
GRASS GIS compilation log
Start of compilation: Thu Sep 6 09:38:18 2001
Errors:
Compilation error in module: src/imagery/i.fft (ignored)
Compilation error in module: src/imagery/i.zc (ignored)
Compilation error in module: src/raster/r.surf.fractal (ignored)
Compilation error in module: src.contrib/GMSL/NVIZ2.2 (ignored)
Compilation error in module: src.contrib/CERL/imagery/i.shape (ignored)
End of compilation: Thu Sep 6 10:20:46 2001
DONE generating GRASS GIS binary code
except for NVIZ this is new.
And src.garden/grass.postgresql does not build any longer too.
There is a hardcoded -lipc somewhere, this is -lcygipc on cygwin.
I have currently not the time to investigate all this further.
I want to ask for some more time, so that i can look. The problem is
that all the recent changes (which are really welcome by me) have to be
tested on different platforms (cygwin, BSD-systems).
Please let us not drop the platform-independence of GRASS just to get
the final version out this week. I invested a lot of time in the cygwin
setup, so that i have to insist on fixing the problems first.
until later,
Andreas
fail too.
OK; I'll add a test for that.
Unfortunately, the only way to determine what dependencies to try is
to collect reports of "configure fails to find libX because it needs libY".
on cygwin:
Does libpng not have gdImageGif either?
$ cat error.log
Errors:
You need the FFTW library (www.fftw.org) for these (except NVIZ). The
previous FFT implementation was non-GPL and was removed.
