Greetings,
A few months ago I offered to create help pages for getting GRASS going on Mac OS X. My time management skills since then have been "questionable". I started a page, collected suggestions from people and a bunch of potentially relevant mailing list posts, but only got around to adding a few points to the actual page.
I've just attempted to get a bit more work done on it, and have concluded that it would be better to make it generally accessible. The "pride issue" - knowing that other people might see my horrible first drafts - tends to motivate me better than keeping things on a long "to-do" list
So I've committed my initial draft to CVS. There are no links to it yet, but if I understand correctly, next time Markus' script runs it will become available as
http://grass.itc.it/macgrass/macgrass.html
In the meantime, you can access it from CVS (web/macgrass) or it's also at:
http://rideau.carleton.ca/~smitch/macgrass/macgrass.html
It is far from complete, I'm just trying to push myself to get the ball rolling a little better. I welcome any suggestions/complaints/corrections that you might have. For those that already contributed material, thanks, and if your suggestions aren't showing up there now it's not that I've rejected them, I just haven't got to it yet!
And if you have CVS write access set up, feel free to edit directly.
Thanks!
Scott W. Mitchell Scott_Mitchell@carleton.ca
Department of Geography and Environmental Studies
Carleton University, B349 Loeb Building (Office A209)
1125 Colonel By Drive, Ottawa, ON Canada K1S 5B6
+1-613-520-2600 ext 2695 Fax: 1-613-520-4301
