[GRASS5] grass user interface description
Dear GRASS developers,
I have updated the parser to escape &, < and >.
I also added the Python GUI builder and the
document type definition in src/gui/python
and src/gui.
For those who have python, wxPython and
python-xml installed, please feel free to test
the gui and report any comment, bug etc.
Current limitations:
A few GRASS commands do not use G_parser(),
some output addtional usage information on their
own. Furthermore, the short description is
currently missing, because it is not incorporated
in the commands. Interactive-only commands
(e.g. i.composite) don't work either.
tcltkgrass and xml user interface description:
In principle, it is quite simple to make tcltkgrass
use the xml-based user interface description as well
and thus
(1) get rid of the module descriptions and
(2) update the tcltkgrass user interface.
First, a simple structure for the short description
needs to be added for the parser and second,
(just some work :slight_smile: all commands need to define their
short description.
Finally, before the tcl evaluation of the currently
used tcl list structure, the corresponding command
must be called with --interface-description and
the output parsed into the currently used list structure.
  Jan
Jan-Oliver Wagner http://intevation.de/~jan/
Intevation GmbH http://intevation.de/
FreeGIS http://freegis.org/
subject 'unsubscribe grass5'
I have added module descriptions to
s.in.shape/cmd/main.c
s.info/main.c
s.kcv/main.c
s.normal/main.c
s.out.ascii/main.c
s.out.e00/s.out.e00.c
s.perturb/main.c
s.probplt/probplot.c
s.proj/main.c
s.qcount/main.c
s.random/main.c
s.sample/main.c
s.surf.idw/cmd/main.c
s.surf.krig/main.c
s.surf.rst/main.c
s.sv/main.c
s.territory/main.c
s.to.rast/main.c
s.to.vect/cmd/main.c
s.univar/main.c
s.windavg/main.c
The modules:
s.datum.shift
s.in.ascii
s.in.mif
have been updated by Andreas.
The modules:
s.menu
s.geom
are *not* updated as they are not (yet) runing within GRASS 5.
s.o2n.tps is internal only.
thanks Markus.
s.surf.krig/main.c
that one did not compile on my platform.
Will investigate further.
The modules:
thanks Andreas.
I have update
v.timestamp v.to.db v.to.rast v.to.sites
v.transform v.trim v.what
Still 273 modules to go ... :slight_smile:
Jan
Hi Jan-Oliver,
i have updated some other modules too:
m.clump
m.datum.shift
s.datum.shift (not compiled by default)
v.in.atlas
v.out.atlas
d.listcolors (new, not compiled by default)
I have no special order to proceed, just implementing if i encounter a
module source code for other reasons (not compiling, not working,
bugfixing etc.).
I don't plan to maintain a list by hand, as this can be done with a
script (grep'ing for the keyword in output of script).
cu,
Andreas
Jan-Oliver Wagner wrote:
thanks Markus.
> s.surf.krig/main.c
> The modules:
thanks Andreas.
I have update
Jan
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange@Rhein-Main.de - A.C.Lange@GMX.net
Hi Andreas,
great!
bugfixing etc.).
Thats OK.
Yes, I initially thought to do it that way, but it turned out
that for my purpose to track the proceeding of this activity
needed some additional information. So a yes/no indicator method
was not sufficient.
Also updated:
v.spag v.stats v.support v.surf.rst
To go: 266 commands
My hope is that we get the module information feature build into
GRASS before the next release. A brave task :slight_smile:
  Jan
