[GRASS5] Grass51 and OGR
I have a question about the status of "v.out.ogr". I tried to output a vector file to shape and get following error:
v.out.ogr: relocation error: v.out.ogr: undefined symbol: OGRGetDriverCount
I used this command:
v.out.ogr input=strassen type=line dsn=/home/harald/temp layer=test1 field=1
grass-versions:
50 and 51 versions from 2003-05-24 cvs-snaphots
gdal:
1.1.8
Do you have any hints?
Harald
Harald Wehr said:
OGRGetDriverCount
field=1
grass-versions:
gdal:
1.1.8
No hints, only that with a more recent cvs version I do not have this
problem.
However, the resulting dbf file is unusable since containing only 0's or
different very strange symbols.
Moritz
On Wed, May 28, 2003 at 01:46:05PM +0200, Harald Wehr wrote:
Check if it is defined in your OGR:
cd /ssi0/ssi/neteler/soft/gdal/ogr
grep OGRGetDriverCount *
ogr_api.h:int CPL_DLL OGRGetDriverCount();
ogr_capi_test.c: numDrivers = OGRGetDriverCount();
For me it compiles (I am using GDAL from CVS).
