[GRASS5] grass5install.sh error on mac os x
Hello all:
I received the error below after cat'ing Jeshua's binary pieces. The installer didn't recognize the cat'ed package as a .tar.gz, when I added the .tar.gz when cat'ing. Then I tried cat'ing to a file named 'grass5.0beta11_Darwin_bin' and tar'ing and gz'ing it. This solved the installer's problem with .tar.gz. Below is the output after running the install script.
Andy Agena
[localhost:/opt/grass5beta11] root# sh grass5install.sh grass5.0beta11_Darwin_bin.tar.gz
GRASS GIS 5 binary package installation tool
Checking and creating installation directory...
/usr/local/grass5
/usr/bin/gunzip
Using gunzip decompressor...
The package grass5.0beta11_Darwin_bin.tar.gz seems to be o.k.
Proceeding...
Installing GRASS binaries into /usr/local/grass5
Uncompressing the package and extracting to target directory...
grass5install.sh: read-only variable: PWD [217]
Creating start script: /usr/local/bin/grass5
awk: can't open file /usr/local/grass5/grass5
source line number 7
Creating the locks directory for monitors...
cp: /usr/local/grass5/etc/monitorcap: No such file or directory
grass5install.sh: no such file or directory: /usr/local/grass5/etc/monitorcap [269]
Creating the monitor fifos...
/usr/local/grass5/dev/create_fifos.sh: can't open input file: /usr/local/grass5/dev/create_fifos.sh
Installation finished. Start GRASS 5 with
    grass5
The graphical user interface can be started within GRASS GIS.
Welcome to GRASS GIS. Enjoy this open source GNU GRASS GIS!
[localhost:/opt/grass5beta11] root# grass5
subject 'unsubscribe grass5'
On Wed, Feb 14, 2001 at 07:39:23AM -0600, andy agena wrote:
Hello all:
install script.
Andy Agena
Jeshua,
didn't you split the tar.gz package? If not, how to make one package
from it? Obviously the cat is wrong.
/usr/local/grass5
/usr/bin/gunzip
Proceeding...
    grass5
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
> Hello all:
> install script.
> Thanks,
> Andy Agena
Jeshua,
Hi Markus,
Yes, the package was split. And per your suggestions on how to split segments you instructed to join using cat.
Here's what you said (private correspondence) on Tue, 14 Nov 2000 14:02:05 +0000:
Yes, of course:
       split - split a file into pieces
Split into 5MB packages:
split --bytes=5m bigfile.tar.gz prefix=grass5_macosX_bin.
add the dot!
the numbering is .aa .ab. ac etc
To put them together later use
cat grass5_macosX_bin.aa grass5_macosX_bin.ab > bigfile.tar.gz
I myself have never joined a gzip, only split them. I notice you have published the segments, perhaps you can join the segments and post it??? BTW: if you don't use cat, what do you use?
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
---------------------------------------- If you want to unsubscribe from GRASS Development Team mailing list write to:
> > Hello all:
> > install script.
> > Thanks,
> > Andy Agena
>Jeshua,
> Markus
Hi Markus,
14:02:05 +0000:
>Yes, of course:
>add the dot!
I have no idea about this. Currently the new MacOS-GRASS seems to be
corrupted.
Even "file" cannot detect the format. If Jeshua has no time to package
it again, could you, Andy, compile and package it?
Or, Jeshua, maybe you uploaded in ASCII instead of BIN to your server?
Or my "wget" didn't get it properly?
Sorry for no better news,
> > > Hello all:
> > > install script.
> > > Thanks,
> > > Andy Agena
> >Jeshua,
> > Markus
> Hi Markus,
> 14:02:05 +0000:
> >Yes, of course:
> >add the dot!
corrupted.
Hello,
Oh my! I did upload it as ASCII. I will upload it again as binaries right now...
For some reason I was thinking ASCII was the correct transfer mode...
Sorry,
Jeshua Lacock
Cartographer/Owner
