[GRASS5] _gtty & _stty errors
On Saturday, December 9, 2000, at 07:06 PM, Eric G . Miller wrote:
> OK, I'm back after re-installing my system.
> It appears that gtty and stty are defined in the header libc.h (which
> is on my system), however I cannot locate the archive libc.a anywhere
> on my system. I suspect that this may be the problem, can someone
> confirm this?
> Does anyone know where to get libc.a? Would it work if someone
> emailed it to me (off list, of course)?
You need to get a copy of the static C library for Mac OS X. Possibly
available in developer's resources or some such. Apparently you only
have the shared libes ?? (libc.so or libc.o). It's likely much to big
to mail and it *must* be built for that system. Mine weighs in around
2.5 MB.
Hi Eric,
Thanks for your help.
I'm not sure about your question. In /usr/include I have libc.h and libc.p (no libc.o or libc.so). I do not have any libc*.* files in /usr/lib....
I am having a hard time finding the static C lib. Does GNU have a distribution? Maybe gcc?
If you ftp'ed the lib, could I build it for my system? If so, please ftp to ftp.SierraMaps.com/pub/
Thanks again,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
> > confirm this?
> 2.5 MB.
Hi Eric,
/usr/lib....
I find it hard to believe there is no C library. Did you check in /lib
as well? (it wouldn't be in an include directory). How'd you manage to
build stuff before without the static library? I always get a linker
error (but then, all the shared libraries are stripped of symbols too).
Yes, but there're complications with having more than one C library on
the system, especially if they're from different "vendors".
Yes you could get GNU Libc, but maybe you'd be better off getting the
libc that gets distributed with the BSD's (I believe it's different).
I think that maybe you could build it in /usr/local/lib, but then you
may or may not need to use an LD_PRELOAD=/usr/local/lib/libc.so.6 or
whatever in order to run GRASS programs and not have them do weird
things. I don't know for sure.
Eric G. Miller <egm2@jps.net>
