These are the details of the 19 files which genuinely differ between
the head and the release branch.
1. src.garden/grass.postgresql/g.select.pg/Gmakefile
src.garden/grass.postgresql/g.select.pg/getdbname.c
src.garden/grass.postgresql/g.select.pg/listdb.c
src.garden/grass.postgresql/g.select.pg/main.c
src.garden/grass.postgresql/g.table.pg/Gmakefile
src.garden/grass.postgresql/g.table.pg/infxTable.c
src.garden/grass.postgresql/g.table.pg/main.c
These are due to Alex' i18n changes.
2. src/CMD/head/head.in
Addition of INST_DIR, apparently due to 1 above.
3. src/CMD/lists/GRASS
Removal of d.area, addition of d.vect.area, d.vect.line.
4. src/include/gis.h
Change type of "checker" field in definition of "struct Option":
- int (*checker)(); /* Routine to check answer or NULL */
+ int (*checker)(const char *); /* Routine to check answer or NULL:
+ * > 0 --> error, 0 == OK
5. src/include/gisdefs.h
src/libes/gis/plot.c
Addition of G_plot_area()
6. src/tcltkgrass/main/menu.tcl
Remove menu entry for d.area, add entries for d.vect.area, d.vect.line
Disable (inactive) "Display USGS DLG-3 files" menu entry.
7. src/display/d.dm/d.dm
src/display/d.vect/cmd/local_proto.h
src/display/d.vect/cmd/main.c
src/display/d.vect/cmd/plotCat.c
src/mapdev/v.alabel/main.c
src/mapdev/v.llabel/main.c
Various changes, suggesting work in progress.
