[GRASS5] how to install grass5b on alphaServer
Hi! I am a student studying GRASS in Korea.
I have a problem to install Grass based on Compaq alpaha Server.
So, I would like to know how to install Grass5beta6_linuxbin.tar.gz on alphaServer.
The problem is this:
  .....installing .....
Creating Monitor fifos ...
Processing stopped after this messesage. I can't help waiting Your reply as quickly as possible.
Your help would be greatly appreciated!
Thanks!
Jerry
No. 1 ¿ì¸® ÀÎÅͳÝ, Daum
Æò»ý ¾²´Â ¹«·á E-mail ÁÖ¼Ò ÇѸÞÀϳÝ
Áö±¸ÃÌ ÇÑ±Û °Ë»ö¼­ºñ½º Daum FIREBALL
http://www.daum.net
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
subject 'unsubscribe grass5'
length: 2137
max: 0
Thanks!
Hi Jerry,
please do not flood the different mailing lists with copies of the same
message.
The binary files (grass5.beta6/7_linuxbin.tar.gz) are platform and
operating-system specific. The linux binary from the hannover server is
for Linux on Intel x86 architecture only. I don't know if a alpha-linux
binary will be released in the near future. If you want to install
grass5 now you must get the source file (grass5.0beta7.tar.gz), unpack
it and compile it.
You did'nt tell which operating system you run on the Compaq Alpha
Server (Linux? Digital Unix, TrueUnix?). You need a compiler (gcc/egcs)
to build grass5 from the sources. I don't know if someone successfully
compiled grass5 with the native compiler for TrueUnix etc.
cu
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange@Rhein-Main.de, A.C.Lange@GMX.net
length: 2734
max: 0
Just as a side note: I remember that Gnu/Linux/Alpha had a binary x86
emulator. So in theroy it might be possible to run the linux binary
somehow.
Unlikely.
it and compile it.
The command
  uname -a
will tell him. :slight_smile:
The command
  cc -V
or
  cc -v
might tell him his compiler version.
I had some success in building grass5 on OSF1 (now called TrueUnix)
and the native compiler. In fact the native compiler is quite nice
and discovered some problems of the gcc centric development.
  Bernhard
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
