[GRASS5] i.pca and masks
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I did some PCA on images using different masks and only then I noticed
that in the end I got the full image, without a mask. However in the man
page it says:
The current geographic region definition and mask settings are respected
when reading the input raster map layers
What does this mean? That it uses the mask only for making the pca
calculations, but then shows up the whole image?
If I would want to build up a image on the mask area (hard disk
space...), would it be possible?
Gualter Barbas Baptista
gualter@gaia.org.pt ICQ# 8106393 jabber.org: gandhiano
GAIA - Grupo de Acção e Intervenção Ambiental
gaia@gaia.org.pt
Portugal
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQE9ilgtNKPP62B6z9cRAv5RAKDRr0FNkw1PJi7InO38ox62YHaHKgCfaC+0
SBvcWOR/dl1zuduUFQf2KkQ=
=AiEz
-----END PGP SIGNATURE-----
Hash: SHA1
I should further add that the i.pca on the different masks (and without
mask) looks exactly the same, so I don't really think he's using the
mask for the input.
| page it says:
| Thanks,
| gaia@gaia.org.pt
| Portugal
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
gaia@gaia.org.pt
Portugal
gaia@gaia.org.pt
Portugal
iD8DBQE9ilrMNKPP62B6z9cRAssNAKC6wyybEh0CaCAluHghvlcXqs/L7ACgzDHZ
7mEedlPiA7GU+2CrBFkF8ls=
=zb2w
page it says:
It's a bug in one of the core functions, G_get_map_row(), which is
used for reading maps. This function is supposed to automatically take
account of the mask, but it doesn't; in reality this function is
identical to G_get_map_row_nomask().
The net result is that any module which uses G_get_map_row() rather
than G_get_raster_row() etc will completely ignore the mask.
Note: this bug is present in the earliest CVS version, dating back to
1999/12/29. It isn't present in 4.3; between 4.3 and the earliest CVS
version, src/libes/gis/get_row.c was completely rewritten to handle
floating-point and null values.
If you built GRASS from source code, apply the attached patch and
recompile. Otherwise, wait for 5.0.1.
(attachments)
grass-nomask.patch (647 Bytes)
Hash: SHA1
I didn't, but I would like to do it now. However, I don't find the source code for 5.0.0, only for the pre5. Is there any branch on CVS for getting the final release of 5.0.0?
gaia@gaia.org.pt
Portugal
iD8DBQE9jF6DNKPP62B6z9cRAtjlAKCF82oCB4o8gJTWVOzjrj6t9ldbYgCeLJpe
Yfd9PxCj/UrAO7JZC1XVySc=
=xInd
This is it. I noticed that the accompanying text still says preX,
that needs to be removed.
Helena
http://grass.itc.it/grass5/source/
Hash: SHA1
gaia@gaia.org.pt
Portugal
=xInd
grass5 mailing list
grass5@grass.itc.it
Hash: SHA1
On Sat, 21 Sep 2002 12:56:51 +0100, Gualter Barbas Baptista <gualter@netcabo.pt> wrote:
Moritz
Version: GnuPG v1.0.7 (GNU/Linux)
Comment: Processed by Mailcrypt 3.5.6 <http://mailcrypt.sourceforge.net/&gt;
iD8DBQE9jGLZyrpWRtQydA0RApUrAJ9/KutHQVds7CreY3Rml2DyRqKf7gCffeJw
nnllD0FdoGRhvTEzCvF048w=
=l26f
Hash: SHA1
done
Moritz
iD8DBQE9jGT3yrpWRtQydA0RArR4AJ9ZuL+OOZItjEE0Q7I/vDH28yJqTACg03ef
kl88t3ulq8Der3Qm8q95LSU=
=h5u7
The 5.0.0 release has the (non-branch) tag:
  release_30_08_2002_grass5_0_0
I have updated the CVS tags page:
http://grass.itc.it/grasscvstags.html
Hopefully it is a bit better now. Let me know if not.
