[GRASS5] linking grass5.0 modules
Hy to all...
I succesfully installed grass 5.1 on my pc...... (I hope... :slight_smile:
Now I have two problem:
at the moment I start it, (dist/ARCH/bin/grass51) the program start without
asking anyting about location and mapset..... It's normal???
When, after, I use d.rast I see that I'm on a location that I created with
grass 5.0, but I don't know why grass51 chose this one and not another one.
why this appen???
another problem
I tried to link the file /usr/lib/grass5/etc/bin/cmd/d.what.rast
inside the directory
......./grass51_exp_2002_12_13/dist.i686-pc-linux-gnu/etc/bin/cmd
and the file /usr/lib/grass5/bin/d.what.rast
......./grass51_exp_2002_12_13/dist.i686-pc-linux-gnu/bin
but when I try to use it, after opening x0 monitor, I obtain this:
Buttons
Left: what's here
Right: quit
1671371.875(E) 4833629.79166667(N)
regione in curvelivello, quant (221)
regione in curvelivello, actual (222.339706)
Monitor <x0>: Premature EOF
ERROR eof from graphics driver.
The program stop and I'm not able to continue the analysis...
can someone help me???
thank you
Ivan Marchesini
University of Perugia
On Tuesday 07 January 2003 10:45 am, Ivan Marchesini wrote:
Hy to all...
why this appen???
GUI interface for startup is not yet present in 5.1 and
init.sh skips the dialog for the first time or for -tcltk (bug).
'grass51 -text' should be OK, I updated init.sh to force the text mode.
another problem
Buttons
Left: what's here
Right: quit
Some monitor functions for interaction with user were changed
in 5.1 so that it is impossible to run interactive modules (d.what.*)
from 5.0 in 5.1.
I added d.what.rast to 5.1 CVS.
Radim
