[GRASS5] NVIZ Compiling Error
After adding tkIntDecls8.4.h and tkInt8.4.h to
src.contrib/GMSL/NVIZ2.2/src
and updating
src.contrib/GMSL/NVIZ2.2/src/interface.h
it seems that NVIZ compiles now also with tcl/tk8.4.
Dear List,
- Compiling NVIZ from grass cvs (HEAD) snapshot from 04-Oct-2002 on my
  linux now works with Tcl/Tk 8.4 and gcc version 3.2 -> grazie Markus !
but ...
Using NVIZ another problem appeared. All! functions work, but I get
error
messages setting height, zexag and perspective:
   invalid command name "tkCancelRepeat"
        while executing
   "tkCancelRepeat"
        (command bound to event)
Does anybody has a solution for this ?
thanks
  Otto
but ...
error
        while executing
   "tkCancelRepeat"
tkCancelRepeat is a built-in command in Tcl/Tk 8.0 (and presumably up
to 8.3, as no-one else has reported this).
Unless we can determine that 8.4 has a replacement, we should define a
stub, e.g.
  if {[string length [info commands tkCancelRepeat]]} {} {
  proc tkCancelRepeat {} {}
On Friday, October 11, 2002, at 11:42 AM, Glynn Clements wrote:
        while executing
   "tkCancelRepeat"
stub, e.g.
Greetings,
I have created a patch which fixes the problem. The screen is now automatically redrawn.
The solution "restores the existence of the Tk private command(s)". I came across it at:
  < http://www.tcl.tk/cgi-bin/tct/tip/44.html
*** old/widgets.tcl Mon Oct 14 23:51:42 2002
--- new/widgets.tcl Mon Oct 14 23:50:47 2002
*** 248,255 ****
--- 248,264 ----
   #Bind For Re-Draw Surface
       bind $S.scale <Any-ButtonRelease> {+
+ if {![llength [info commands tkCancelRepeat]]} {
+ tk::unsupported::ExposePrivateCommand tkCancelRepeat
   tkCancelRepeat
+ if {![llength [info commands tkScaleEndDrag]]} {
+ tk::unsupported::ExposePrivateCommand tkScaleEndDrag
   tkScaleEndDrag %W
+ if {![llength [info commands tkScaleActivate]]} {
+ tk::unsupported::ExposePrivateCommand tkScaleActivate
   tkScaleActivate %W %x %y
   if {[Nauto_draw] == 1} {Ndraw_all} }
*** 298,305 ****
--- 307,323 ----
   tkCancelRepeat
   tkScaleEndDrag %W
Jeshua Lacock __________________________
Programmer/Owner Phone: 760.935.4736
http://OpenOSX.com Fax: 760.935.4845
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
>> while executing
>> "tkCancelRepeat"
>> (command bound to event)?
   tkCancelRepeat
   tkScaleEndDrag %W
thanks a lot for your help.
finally a mixture of your ideas seem to be
a solution. The automatic Re-Draw unfortunately does not work
- NVIZ compiles, but does not start.
adding this to the top of src.contrib/GMSL/NVIZ2.2/scripts/widgets.tcl
makes NVIZ work fine again!:
thanks again for your help.
  Otto
PS: If you have any solution for the automatic Re-Draw
error -> I could test your ideas -> errors are:
Error in startup script: can't read "S": no such variable
    while executing
"bind $S.scale <Any-ButtonRelease> {
i..."
    (file "/usr/local/grass5/etc/nviz2.2/scripts/widgets.tcl" line 11)
    invoked from within
"source /usr/local/grass5/etc/nviz2.2/scripts/widgets.tcl"
    ("uplevel" body line 1)
    invoked from within
"uplevel #0 $auto_index($name)"
    (procedure "auto_load" line 13)
    invoked from within
"auto_load $name [uplevel 1 {::namespace current}]"
    (autoloading "Nv_mkMenu")
    invoked from within
"Nv_mkMenu $Nv_(AREA).menu.file File {"Load State..." "Save State..."
"Load 3d Settings..." "Save 3d Settings..." "Image Dump..." "Reset"
"Quit" } {..."
    (procedure "Nv_makeGUI" line 59)
    invoked from within
"Nv_makeGUI .top"
    (file "/usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script" line
660)
child process exited abnormally
    while executing
"exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f
/usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script -q -name NVIZ
&@stdout"
    ("eval" body line 1)
    invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ
&@stdout"
    invoked from within
"if {$argv == ""} {
#no arguments
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
    (file "/usr/local/grass5/bin/nviz" line 16)
>> while executing
>> "tkCancelRepeat"
> stub, e.g.
Greetings,
came across it at:
  < Tcl Improvement Proposals: TIP 44: Move Tk’s Private Commands and Variables into ::tk Namespace
I have applied this patch to CVS.
