1. All the thematic options calculate 'breakpoints' where the color change
in the thematic map: at a set of regular intervals (the number of intervals
defined by the user), 2 standard deviation units around the mean, quartiles,
and custom. The custom option just lets you define manually where the color
changes rather than having it determined by an algorithm (as it is for other
3 options).
2. You can put values into the GRASSRGB column for all vector types.
Currently d.vect only displays colors in this column for areas. According to
Hamish, this is being extended to lines and points.
Michael
______________________________
Arizona State University
Tempe, AZ 85287-2402
USA
----- Original Message ----- From: "Michael Barton" <michael.barton@asu.edu>
To: "Maciek Sieczka" <werchowyna@epf.pl>; "grass devel"
<grass5@grass.itc.it>
Sent: Tuesday, May 31, 2005 9:32 PM
Subject: Re: [GRASS5] on d.vect.thematic
Maciek,
intervals
color
other
3 options).
Thanks for explaining this. Could it be elaborated similarly in the manual
(and include a note you are talking about options "themecalc" and "nint").
to
Great, now I see. But manual says "Thematic colors can be uploaded to a
GRASSRGB column for later display (areas only) ...". This made me think it's
due to d.vect.thematic itself. I think this sentence should be changed to
avoid such missinformation.
