[GRASS5] "Output - GIS.m" window - what do the icons mean?
Hi
There are neat icons in the "Output - GIS.m" window. It is not
explained what they are for. Could anybody do it please?
1. Those most colorfull ones, on the left - do they only indicate the
command used? They are button like - but does anything special happen
when I push the button?
2. When I click the command syntax, it is printed in the window below.
But the same happens if I push the button 1. What the difference, if
any? Should both perform the same action?
3. For d.rast, a printer icon pops up. What happens when I press it?
4. Then there is a "window symbol". I can also push it, but nothing
happens. Should anything happen?
See the attached screendump for guiding.
Also - could the mouse cursor change into an arrow when over those
icons/buttons, like it does in main gis.m window?
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
(attachments)
Maciek,
Sorry I haven't really explained any of this yet. I have no idea where it
should go in the documentation. This is partially the same as the output in
the generic user interface.
They do indeed. When you push the button (gis.m only) the command is copied to
the text box for entering commands at the bottom of the screen.
Both do the same.
The output of the command is shown / hidden. Some of the display commands
output a single blank line of text, which isn't very exciting.
That's shown when the command originated in gis.m. It's not supposed to be a
button (it's flat) but it's still pushable. The output widget has the ability
to show icons or text for all sorts of statuses or flags. Right now it just
does gis.m, xterm, errors, output, and running.
Yeah, it should probably be an arrow here.
--Cedric
commands output a single blank line of text, which isn't very
exciting.
                                         __
printer is misleading... what about a <| \/ triangle? or +/-
it would be nifty if this had the Display Map window ID number embossed
on it, so you knew which instance you were dealing with.
Hamish
Maybe an open and shut folder??
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Thu, 4 May 2006 22:05:14 +1200
To: Cedric Shock <cedricgrass@shockfamily.net>
Cc: <grass5@grass.itc.it>, <werchowyna@epf.pl>, <michael.barton@asu.edu>
Subject: Re: [GRASS5] "Output - GIS.m" window - what do the icons mean?
exciting.
                                         __
Hamish
>it? >
>> exciting.
> __
> embossed on it, so you knew which instance you were dealing with.
too subtle?
Hamish
