[GRASS5] Package name convention - was: Re: [GRASSLIST:311] Re: Source packages
[moved to developers list]
Dear developers,
below is a proposal for a modified name convention of GRASS source
packages.
Should we follow below suggestion?
Thanks for comments,
On Fri, Jun 06, 2003 at 04:50:05PM +0200, Buchan Milne wrote:
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Markus Neteler wrote:
> On Wed, Jun 04, 2003 at 01:03:02PM -0400, R. Sean Fulton wrote:
>>Is there a convention for naming GRASS source packages? I ask because
>>I've been playing with building RPMS and DarwinPorts packages which
>>assume the source package name and the extracted directory name will
>>be the same. (e.g. they expect grass-5.0.2_src.tar.gz to extract to
>>'grass-5.0.2_src/' but it extracts to 'grass5.0.2/')
>>That's an oversimplification, there are work-arounds but there seems
>>to be a convention of APPNAME-VERION for the source directory.
> Mea culpa - the *GRASS* naming "convention" was a sort of evolving
> over the years.
>>Has this issue ever come up? Are the maintainers aware of it? Do you
>>think anyone cares?
> Not yet :slight_smile: But I see no problem to update the scripts to follow
> a well known naming convention. Let me know what's common and
> I'll update the cronjobs.
%{name}-%version}.tar.gz containing %{name}-%{version}/ is customary,
for about 90% of the packages I have made, then some have
%{name}-%{version}_src.tar.gz containing %{name}-%version}/ .
Since source is typically the standard way of distribution, and there is
no such thing as a generic binary, IMHO, the _src suffix to the version
is useless.
The big thing though is that the directory name should be
%{name}-%{version}, to avoid having all RPM packagers having to add "-n
%{name}%{version}" or "-n %{name}_%{version}" or similar to %setup.
Most important thing is to be consistent though ... otherwise we keep
having to make patches like this for no reason:
http://cvs.mandrakesoft.com/cgi-bin/cvsweb.cgi/contrib-SPECS/grass/grass.spec.diff?r1=1.7&r2=1.8
- -%setup -q
+%setup -q -n %{name}%{version}
>>It's certainly nothing critical, I'm just curious.
> No problem. If things can be made better, we should improve them.
It's been mentioned before (so 5.0.0 was right), so chances are that the
actual naming of the directory in a release is not done by a script, but
should be ...
Buchan
|--------------Another happy Mandrake Club member--------------|
Buchan Milne Mechanical Engineer, Network Manager
Cellphone * Work +27 82 472 2231 * +27 21 8828820x202
Stellenbosch Automotive Engineering http://www.cae.co.za
GPG Key Blog - Mikula Beutl - SEO Consulting
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQE+4KodrJK6UGDSBKcRAiJmAJ9LkQMnVuYbNS7SIxe39Ns1cCzd6QCgsfri
qvPlFLeoJ2DP0LKRjuVhDZQ=
=O46V
-----END PGP SIGNATURE-----
Please click on http://www.cae.co.za/disclaimer.htm to read our
e-mail disclaimer or send an e-mail to info@cae.co.za for a copy.
Dear developers,
packages.
my recommendation is grass-5.0.2.tar.gz,
ie. $name-$version.tar.gz
where version is always a triplet, but could also look like
5.1.0pre1 pr 5.2.0rc1
[which implicates my proposal on how to name pre-releases and
release candidates - well, pretty common in the Free Software
world]
Using the suffix 'src' indeed is quite useless.
Instead, binaries should have some suffixes (which must indicate
the platform anyway).
  Jan
Jan-Oliver Wagner http://intevation.de/~jan/
Intevation GmbH http://intevation.de/
FreeGIS http://freegis.org/
Hash: SHA1
Dear developers,
packages.
world]
Does anyone else agree with this? Can it be adopted (and put into
release-management scripts?).
Oh, and while we're discussing pre-releases, any suggestoins on
numbering packages of grass51 from CVS, besides using 5.1.0cvs$date (ie
for a package grass51-5.1.0-0.cvs20030614.1mdk.i586.rpm instead of the
one I currently use:
http://ranger.dnsalias.com/mandrake/9.1/grass51-5.0.99-0.cvs20030614.1mdk.i586.rpm
Buchan
GPG Key http://ranger.dnsalias.com/bgmilne.asc
iD8DBQE+9uaorJK6UGDSBKcRAuUBAKC+j8XFKR8O6KffsnrJJUZd+3iTcgCgiBVH
zeeLwOB9CZsIGlIZE4DG36k=
=HPDu
