The attached patches will remove the legacy Tape_Info struct and
associated functions from lib/imagery.
After applied, the files advance.c, band_io.c and tape_info.c can be
removed.
3 comments:
a) what functionality is lost? (which modules would be removed from the
to-be-ported list?) Can anyone comment on Tape storage functions used in
historical versions of GRASS?
b) It is nice to keep cosmetic / simple fixes separate from functional
changes in the diff files. This makes understanding and tracking
fundamental changes in the CVS easier (also makes it easier to back them
out later if needed). On the other side, the small changes can be
applied quickly without much debate and less review.
c) I take it this fixes a "reached the end of non-void fn" warning.
i) this fn can probably be replaced by G_percent() and removed.
ii) an exit code of 0 should be used, not 1. The UNIX convention is
zero means success, else means failed. (many ways to fail)
> removed.
3 comments:
I assume you are talking about the TODO file that shows the to-be-ported
list? The only modules to use Tape_Info were the i.tape.* commands. I
asked Markus about it and he seemed to think it was legacy code.
I'm sorry. I also included a couple compiler compaints, as well. I'll
submit them separately from now on. I'll make the changes noted below
and resubmit properly.
x = n*100/d ;
- if (x % s) return;
+ if (x % s) return 1;
if (n <= 0 || n >= d || x != prev)
prev = x;
@@ -36,4 +36,6 @@
fprintf (stdout,"\n");
prev = -1;
+ return 1;
Yes, it was a fix for "end of non-void fn". Generally, I use
EXIT_SUCCESS or EXIT_FAILURE to avoid such things, but I was trying to
keep to GRASS style. I'll look into replacing with G_percent().
