[GRASS5] please commit indent by itself
[GRASS-CVS] markus: grass6/vector/v.out.ascii b2a.c,1.4,1.5
head.c,1.2,1.3 local_proto.h,1.2,1.3 out.c,1.5,1.6
Update of /grassrepository/grass6/vector/v.out.ascii
In directory doto:/tmp/cvs-serv15591
Modified Files:
  b2a.c head.c local_proto.h out.c
Log Message:
[...] added option dp to truncate the float output of point coordinates;
added localisation; code prettified with indent
If you commit an indent change at the same time as other changes, it
makes it very hard to use diff to see what the code changes really were,
chase bugs, etc. Please commit indent changes by themselves. It's also
a good idea to list the indent switches used in the CVS log so if
someone wants to use diff they can.
Suggested indent rules are not in the SUBMITTING file; shall we ask for
these? (same or similar to those scattered throughout the changelog)
$ indent -nbad -bap -bbb -nbbo -nbc -br -bli1 -bls -cbi0 -ncdb -nce \
-ci4 -cli0 -ncs -d0 -di0 -fc1 -nfca -hnl -i4 -ip4 -l80 -lc80 -lp -npcs \
-pi4 -nprs -npsl -sbi0 -sc -nsob -ss -ts8 main.c
cheers,
Hamish
Modified Files:
Log Message:
Hamish,
you are absolutely right.
Sorry for that.
Please add them to SUBMITTING. If anyone disagrees, we can modify
there again.
