[GRASS5] png import with r.in.png and r.in.gdal question
When importing the attached png image with 57 r.in.gdal to a xy location, I receive the following messages
r.in.gdal input=/home/grassdata/scan_small.png output=scan_small57gdal
Projection of input dataset and current location appear to match.
Proceeding with import...
CREATING SUPPORT FILES FOR scan_small57gdal
SETTING GREY COLOR TABLE FOR scan_small57gdal (8bit, full range)
Looks like there is no obvious error, but the map is empty.
When using 55 r.in.png input=scan_small.png output=scan_small55png it is ok.
The png image was scanned using xsane and gimp 2.0 with default settings.
Do I miss some import flags or does r.in.gdal expect specific settings when creating the png image?
Mit freundlichen Grüßen / With kindest regards
Stefan Paulick
http://www.urbeli.com
mailto://stefan.paulick@urbeli.com
(attachments)
I tried: no problem. Probably you forgot to zoom to the map:
r.in.gdal in=/tmp/scan_small.png out=scan_small.png -o
g.region rast=scan_small.png -p
d.erase
Hope this helps
