[GRASS5] Problems compiling tk
Hi Christian:
If you're using fFnk<http://fink.sourceforge.net/&gt;, I have instructions here: <http://grasstep.sourceforge.net/&gt;\. Fink was just upgraded this week to support Jaguar, so you won't have to mickey mouse with the CVS.
Though if you want to use the libraries you've installed, its probably just a question of pointing your ./configure to the right place: ./configure --with-tcltk-includes=/path/to/your/tcltk/includes --with-tcltk-libs=/path/to/your/tcltk/libs
Good luck,
Andy
Hi, I'm Christian Tiso, a student that works with Riccardo Rigon in his
Studio. I phoned you today because I'm desperate! Since 1 month I've
tryed to compile grass on Macos X but unsuccesfully. I'm still in the
./configure step because I can't find the right tk.h file. I've tryed
to compile the tk source but every version I downloaded (8.4.1; 8.3.5;
8.3.0; 8.2; 8.1; 8.0) gaves me a different error after the configure,
in the make step. Every version has many different directory: macosx,
generic, unix ecc..The macos directory doesnt have the configure file,
so if you want to compile it you need code warrior (it is written in
the readme file) which I have to buy, or you can use the Makefile
alredy availiable for the macosx, but it doesnt work! The unix
directory has the configure file, but in the make step of every version
i found a different problem. I'm not an expert but I've compiled png,
gd, tiff, zlib, jpg, so I thin I know how to compile under macosx. (I
compiled and installed grass on linux mandrake without problems). I'll
send you all the errors messages, but I think that it is better that
someone gives me the right addres where to download a tk (and tcl to)
version for macosx with all the step to compile and install it. I've
tryied also with the packages for macosx in the apple site, but the
configure with grass doesn't work.
Configure error configuring grass:
checking whether to use Tcl/Tk... yes
checking for location of Tcl/Tk includes...
checking for tcl.h... yes
checking for tk.h... no
configure: error: *** Unable to locate Tk includes.
bash-2.05a$
So, I've tried to compile tcltk:
Make error with tk8.4.1as I typed in the macosx directory "make"
(without configure, don't have configure file):
lot of things then...
cpp-precomp: warning: errors during smart preprocessing, retrying in
basic mode
<built-in>:1:1: no macro name given in #define directive
...failed CompileC /Users/christian/Documents/programmi/pacchetti
Xgrass/tk/macosx/../../build/Development.build/Wish.build/
TkStubLibrary.build/Objects-normal/ppc/tkStubLib.o ...
** BUILD FAILED **
make: *** [develop] Error 1
[timonchiotwin:pacchetti Xgrass/tk/macosx] root#
Configure error with tk8.4.1as I typed in the unix directory
./configure):
checking for Tcl configuration... found
Xgrass/tcl8.4.1/unix/tclConfig.sh
checking for existence of
Xgrass/tcl8.4.1/unix/tclConfig.sh... loading
./configure: /Users/christian/Documents/programmi/pacchetti: No such
file or directory
[timonchiotwin:pacchetti Xgrass/tk8.4.1/unix] root#
Make error with tcl8.4.1as I typed in the unix directory make (after
./configure that worked):
[timonchiotwin:pacchetti Xgrass/tcl8.4.1/unix] root# make
make: *** No rule to make target
`/Users/christian/Documents/programmi/pacchetti', needed by `Makefile'.
  Stop.
I have a list of a lot of others similar errors with previous versions
till the tcl/tk8.0 if you want I'll send you, but let's start with
those one!
Thank you
Christian tiso
