[GRASS5] ProgmanGrass: unsuitable format?
Hi everybody,
I would like to know if it's possible to get (or generate)
an HTML version of the Grass programmer's manual, since the pdf version
is a nightmare when it comes to browse and find function definitions...
a frame based version with a frame for the index and a frame
for the contents would be the best, but something like the grass
manual would be very useful too...
Best regards
Andrea Aime
On Wed, Apr 24, 2002 at 12:40:42PM +0200, Andrea Aime wrote:
Hi everybody,
Hi Andrea,
that's no problem: Just run
  make html
then latex2html is created an HTML version of that book.
If desired, I can add this to the web site.
A hint for PDF: When using acroread, you can click on all
functions (as I have implemented hyperrefs). Enjoy the index
at the end of the PDF book where all functions are listed.
Clicking on them, you reach back the describing text.
Ciao
> Hi everybody,
Hi Andrea,
  make html
A follow-up:
a major drawback of the HTML conversion is that latex2html does
not know about the \Gfunc{} macro - subsequently all functions
are not visible. If we find someone to add this macro definition
to latex2html, we are ready to publish it online.
An example for this Latex macro:
\Gfunc{char *}{G\_ask\_vector\_in\_mapset (char *prompt, char *name)}{prompt
  for an existing vector file}{Asks the user to enter the name of an
  existing vector file in the current mapset.}
\Gfunc{return type}{Function}{short description}{long description}
For volunteers:
http://www.latex2html.org/
Maybe it's easy to add this definition, but I don't have time for that
now.
A hint for PDF: When using XXXXX, you can click on all
xpdf works quite good on pdfs and hyperrefs
and it is Free Software!
- Acrobat reader doesn't display progmangrass at all (complains about
  the inability to load an embedded font, also got warnings about locate
  (ISO-8859-1 vs ISO-8859-15)
- xpdf displays it but fonts are a bit ugly (no AA) and I can't
  see the table of contents in a separate frame
- ghostview displays nice fonts but not toc nor hyperrefs
Latex2html is still under development as far as I can tell...
did anyone complained about the lack of \Gfunc support?
Could \Gfunc be replaced with something else that is supported
by latex2html?
Best regards
Andrea Aime
   Part 1.2Type: application/pgp-signature
Here it runs well, also for many other people, I assume (never
got that complaint).
yes.
no idea about this feature of xpdf
yes
yes
by latex2html?
no :slight_smile: It's doing a lot and simplifies to describe functions.
However, I was wrong: The functions *are* displayed, but a bit
ugly (missing spaces etc).
So in general the result should be more or less complete, only
the index is not generated (which is also fed by my \Gfunc{} macro).
Best regards
Andrea Aime
Feel free to improve it - it is in CVS. After days of conversion from
the original WinWord format I was happy to have it in this shape.
Maybe you just try
make html
and check if you like it. Or you go here now:
http://mpa.itc.it/markus/progmangrass50/
Best,
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
