Is r.composit working for folks who are running a recent cvs version?
I am trying to use it on three not terribly large or unusual files and it seems to get stuck on the second color (I killed the process after 20 minutes or so). Am I being impatient? I don't remember that r.composit was a long or slow process (at least with the default levels=32 setting).
GRASS 6.1.cvs (minnesota_utm):~/projects/wrf/ts2325Exports > r.composite red=t61nr9w_1.red green=t61nr9w_1.green blue=t61nr9w_1.blue output=t61nr9w_1
100%
^C 0%
Kirk
100%
^C 0%
While I'm not sure why, the solution to this problem seems to be that the region settings were not correct. I re-set the region, and r.composite worked fine. Sorry for the confusion.
Kirk
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
