[GRASS5] r.in.srtm zip check
r.in.srtm has this check:
if test ! -f $FILE.hgt.zip ; then
echo "File '$FILE.hgt.zip' not found"
exit 1
fi
ls -1 "$FILE.hgt.zip" | grep zip > /dev/null
if [ $? -ne 0 ] ; then
  echo "$FILE.hgt.zip is no zip file."
  exit 1
fi
is the second one meant to be a check to see that file is a valid ZIP
file? If so, better to check against `file $FILE.hgt.zip` ?
also it should check that `unzip` exists, ala awk. On Debian at least I
don't think it is installed by default. Currently exits cleanly if not
there.
Hamish
exit 1
fi
  exit 1
fi
file?
Yes (if I recall correctly)
Maybe:
file -ib N46E011.hgt.zip
application/x-zip
Fixed like this in CVS.
there.
test added.
thanks
