On Wed, 22 Mar 2006, Wolf Bergenheim wrote:
On Wed, 22 Mar 2006, Hamish wrote:
>> What happened to r.moran? I'd need to calculate Moran's I for a
>> rastermap, but I'm unable to find r.moran in GRASS 6.1. If it has
>> dropped off due to lack of a maintainer, please let me know, and I
>> will gladly update it from GRASS 5.4. Is there perhaps another way to
>> to calculate Moran's I?
> It's not in 5.4, just the man page is.
> It's not the GRASS 5 CVS either, you have to look in the GRASS 4.3
> source code to find it:
> http://grass.ibiblio.org/grass43/source/
Thanks. I'll have to see. It seem that I actually need to do this for
vector areas. so I guess I could make v.autocorrelate that would support
Moran's I and perhaps later Geary's C and other methods. I noticed that
v.autocorr used to exist in grass 5 (or is this again only the manual
page?). Anyway, I'll have a look and see if it is of any use. I know that
the vector engine has changed since then, and much of the code is probably
useless, but the algorithms might be of use... anyway I need it to support
a selected attribute field.
> This means you'll need to add NULL support (instead of 0 as null).
Sure.
> Maybe easier to use the GRASS/R interface and perform the operation in R?
> http://biomserv.univ-lyon1.fr/library/spdep/html/moran.test.html
> http://grass.ibiblio.org/statsgrass/index.php#grassR
You might be right. But I guess it wouldn't work for vectors?
No, vectors are fully supported - in fact a raster would be treated as
cell centre points. See the range of functions for building lists of
neighbours in the R spdep package. Are your vectors points or polygons?
What criteria for neighbours do you need? We can continue thread this on
the STATGRASS list if you like.
Roger
> I think we could use a new wiki page listing all older modules not
> ported; not just the 5.4->6.0 list. e.g. r.fuzzy, d.viewproj, r.casc2d,
> etc.? May save someone some trouble. This probably has to be done by
> hand.
Yes that would be most helpful. Also it could state the reason for the
drop, like that some other module can handle this too, or blank for unknown?
--Wolf
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand@nhh.no
