Hi Justin,
yes, I got it!! The front.end is fixed. I have added
some DEBUG stuff which can be switched on/off (hope that's ok.).
Reason for the problem was that
cmdLine = FALSE;
had to be defined. Obviously is was true by default on Linux, so
all commands were treated as CMD.
Now it's o.k. here, everything runs fine with the updated Gmakefiles.
PS: Hi all, please update src/front.end/, then (to be sure)
make distclean
make
make install
subject 'unsubscribe grass5'
