[GRASS5] Re: [DebianGIS] grass and 64bit
On Thu, Mar 16, 2006 at 02:45:16PM +0100, Francesco P. Lovergine wrote:
On Fri, Mar 17, 2006 at 02:27:45AM +1300, Hamish wrote:
> Now we (theoretically) can compile GRASS with TclTk 8.4, maybe someone
> who knows how can help to bring FFTW into the modern era as well, i.e.
> to use fftw3 not fftw2.
> #ifdef 's to remain backwards compat with v.2 ?
Markus surely can answer better. Anyway, at least it requires updating
to the new API for 3.1 in gmath. It's not rocket science...
IMHO fftw2 dependency is a pain since fftw3 is standard now.
Also, we want to modify in GRASS 6.1, so we can remove the
backwards compat with v.2.
I vote for updating to fftw3 without backwards compatibility
to not complicate the things (and to make it happen).
I've commited fixes to support both 2.x and 3.x.
confirmed; works for me on Debian/Stable i686-32 (P4).
patch (against 6.1-cvs):
  http://grass.itc.it/pipermail/grass-commit/2006-March/021104.html
> > > maybe someone who knows how can help to bring FFTW into the
> > > modern era as well, i.e. to use fftw3 not fftw2.
> > updating to the new API for 3.1 in gmath. It's not rocket
> > science...
i.fft, i.ifft work for me using Debian/Stable's fftw3-dev package.
No noticeable time speedup vs. fftw2 on my test data (both ~5sec).
Hamish
Thanks, Glynn!
This is a great help for packaging GRASS.
Should we backport it to 6.0.x?
Thanks, Glynn!
Probably. It should be "safe", i.e. not have any effect if FFTW 3.x
isn't present.
