[GRASS5] Re: [GRASS-CVS] radim: grass6/lib/proj convert.c,1.18,1.19
should this also be fixed in 6.0.2-CVS?
On Fri, Jan 27, 2006 at 06:47:20PM +0100, grass@intevation.de wrote:
Author: radim
Update of /grassrepository/grass6/lib/proj
In directory doto:/tmp/cvs-serv18826
Modified Files:
  convert.c
Log Message:
use OGRSpatialReferenceH instead of pointer
Index: convert.c
RCS file: /grassrepository/grass6/lib/proj/convert.c,v
retrieving revision 1.18
retrieving revision 1.19
diff -u -d -r1.18 -r1.19
--- convert.c 4 Dec 2005 14:37:08 -0000 1.18
+++ convert.c 27 Jan 2006 17:47:18 -0000 1.19
@@ -226,12 +226,13 @@
int GPJ_osr_to_grass(struct Cell_head *cellhd, struct Key_Value **projinfo,
- struct Key_Value **projunits, OGRSpatialReferenceH *hSRS,
+ struct Key_Value **projunits, OGRSpatialReferenceH *phSRS,
          int interactive)
     struct Key_Value *temp_projinfo;
     char *pszProj4 = NULL, *pszRemaining;
     char *pszProj = NULL;
+ OGRSpatialReferenceH hSRS = *phSRS;
     if( hSRS == NULL )
         goto default_to_xy;
@@ -373,6 +374,7 @@
       /* Need to make a new copy of the string so we don't mess
        * around with the memory inside the OGRSpatialReferenceH? */
       G_asprintf( &pszDatumName, pszDatumNameConst );
             GPJ_DatumNameMassage( &pszDatumName );
grass-commit mailing list
grass-commit@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass-commit
Probably no, because older versions of QGIS
work with the buggy GPJ_osr_to_grass.
I think that it should be fixed from GRASS 6.1 (6.2.0).
Radim
On 1/28/06, Markus Neteler <neteler@itc.it> wrote:
> Author: radim
> Modified Files:
> convert.c
> Log Message:
> Index: convert.c
> int interactive)
> if( hSRS == NULL )
> goto default_to_xy;
> @@ -373,6 +374,7 @@
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
