Dear developers,
a shy wish... If you modify GRASS messages, please take
one more minute to internationalize it. It's simply done
by
- adding #include "glocale.h" on top of the file
- adding the gettext macro _()
This would help a lot!
Thanks
On Sat, Jun 04, 2005 at 08:02:17AM +0200, grass@intevation.de wrote:
Update of /grassrepository/grass6/lib/rst/interp_float
In directory doto:/tmp/cvs-serv21017Modified Files:
segmen2d.c
Log Message:
change warning message so it doesn't clobber G_percent()Index: segmen2d.c
RCS file: /grassrepository/grass6/lib/rst/interp_float/segmen2d.c,v
retrieving revision 2.2
retrieving revision 2.3
diff -u -d -r2.2 -r2.3
--- segmen2d.c 3 Jan 2005 04:03:18 -0000 2.2
+++ segmen2d.c 4 Jun 2005 06:02:15 -0000 2.3
@@ -118,7 +118,10 @@
if (i >= 70)
- fprintf(stderr,"Warning: taking too long to find points for interpolation--please change the region to area where your points are. Continuing calculations...\n");
+ fprintf(stderr, "\n");
+ G_warning("taking too long to find points for interpolation--"
+ "please change the region to area where your points are. "
+ "Continuing calculations...");
break;
i++;
