[GRASS5] Re: GRASS Projections (fwd) - UTM problem
Only thing needed is a one-liner in geo_init.c
This is a newer file (not in 4.2), so I haven't tracked down all
the changes in the projection handling - is this documented somewhere
online? Or was this moved from m.proj to the gislib for some reason?
But I wonder no one has noted this before...
As far as I know, GRASS programs were suppose to use either the proj lib
(e.g., r.proj, v.proj, m.proj) or coorcnv lib (m.*ll*) both of which
include the scale factor of .9996 hard coded. Somebody needs to look into
this more - I wouldn't assume the data has been incorrectly converted.
-Bill
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
subject 'unsubscribe grass5'
length: 1558
max: 0
