Glynn,
It is great news that you have GRASS 5.3 compiling successfully for Cygwin. I have several questions.
1. In the list of Cygwin components you list has having installed (in section of copied message below) are opengl and sunrpc. Are these only necessary for compiling Cygwin or are they also needed for the binaries? I ask because there is an old version of sunrpc on the WinGRASS web page, but the binaries installation instructions ignore it.
2. Can GRASS 5.3 open monitors via the tcltk menu or is it still necessary to do this from the command line using d.mon?
3. If GRASS 5.3 works with tcltk 8.3.4, does that mean that it works with the Cygwin version of tcltk or is it still necessary to install a separate version?
Thanks for your time and help.
Michael
On Monday, February 9, 2004, at 04:01 AM, grass5-request@grass.itc.it wrote:
Done that; NVIZ still works.
-r-xr-xr-x 1 root root 749892 Mar 28 2002 libtcl8.3.a*
-r-xr-xr-x 1 root root 985818 Mar 28 2002 libtk8.3.a*fb69cc3342aa19f3fdb709738f6055e7 libtcl8.3.a
4e60b25c070637250f52aa13d5fcdc47 libtk8.3.aFrom:
2983750b94c52b8a5ce1aa3e39e54e45 xtcltk-8.3.4-CYGWIN.tar.gz
Upon giving the above command, an empty (black) Windows command-line
window appeared; the title bar contained the name of the NVWISH2.2
program. The message
---Type <return> to continue, or q <return> to quit---
then appeared in the terminal where NVIZ was started and on pressing
return, the segmentation fault happened.What do the two question marks and empty brackets mean? Do the provided
xtcltk libaries have debugging information? Does anything else need to be
compiled with debugging turned on?The xtcltk 8.3.4 libraries don't have debug info, but they weren't
compiled with -fomit-frame-pointer, so you should still get a
backtrace, and functions which are from the NVIZ source code can be
debugged.Although, if I run NVWISH2.2 under gdb, I get a segfault in libXext,
but not if I run it directly (with identical arguments).FWIW, the relevant Cygwin components are:
XFree86-bin-4.2.0-3.tar.bz2
XFree86-xserv-4.2.0-37.tar.bz2
binutils-20030307-1.tar.bz2
cygwin-1.3.22-1.tar.bz2
gcc-2.95.3-5.tar.bz2
gdb-20030303-1.tar.bz2
opengl-1.1.0-6.tar.bz2
sunrpc-4.0-1.tar.bz2
zlib-1.1.4-1.tar.bz2--
______________________________
Michael Barton, Professor & Curator
Department of Anthropology
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
