On Thu, 16 Feb 2006 14:29:01 -0200
Carlos "Guâno" Grohmann <carlos.grohmann@gmail.com> wrote:
Hello all, I just compile the last wekk CVS, and tried to rectify a
raster scanned map with i.vpoints, but when I try to select a vector
to be used as reference, it crashes and gives this msg at the bottom
of the window: "ERROR: ask_gis_files: can't read tempfile"
Any ideas?
Carlos
For the record: I confirm the behaviour you describe - I had it on my
friend's box with Grass 6.1 CVS from mid December 2005.
Don't know how it is currently. Can you try with most recent CVS?
Maciek
W polskim Internecie s± setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich! http://katalog.panoramainternetu.pl/
> Any ideas?
Carlos
I have debugged and found the problem - a wrong positioned
G_free() in i.find which is called by i.points and i.vpoints.
Thanks for the fix, Markus. i.vpoists is working, the problem now is that my new compilation can’t run d.m:
GRASS 6.1.cvs (am_sul_SAD69):~ > Error in startup script: can’t read “env(HOSTTYPE)”: no such variable
while executing
“set HOSTTYPE $env(HOSTTYPE)”
(file “/usr/local/grass-6.1.cvs/etc/dm/d.m.tcl” line 42)
of the window: “ERROR: ask_gis_files: can’t read tempfile”
Any ideas?
Carlos
friend’s box with Grass 6.1 CVS from mid December 2005.
It’s fixed in 6.1-CVS now.
Carlos Henrique Grohmann - Guano
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
“Good morning, doctors. I have taken the liberty of removing Windows 95 from my hard drive.”
–The winning entry in a “What were HAL’s first words” contest judged by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
while executing
Any ideas?
Carlos
-set HOSTTYPE $env(HOSTTYPE)
+if {[info exists env(HOSTTYPE)]} {
+ set HOSTTYPE $env(HOSTTYPE)
+} else {
+ set HOSTTYPE ""
Please update from CVS.
new compilation can't run d.m:
GRASS 6.1.cvs (am_sul_SAD69):~ > Error in startup script: can't read
"env(HOSTTYPE)": no such variable
while executing
"set HOSTTYPE $env(HOSTTYPE)"
(file "/usr/local/grass-6.1.cvs/etc/dm/d.m.tcl" line 42)
Now I only have the terminal.
Carlos
> > > Any ideas?
> > Carlos
> It's fixed in 6.1-CVS now.
> Markus
_________________
"Good morning, doctors. I have taken the liberty of removing Windows 95 from
my hard drive."
--The winning entry in a "What were HAL's first words" contest judged by
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
i.vpoints starts ok, I select my raster and my vector. If I start by zooming in the vector, it goes well. So I zoom in the raster, select the point in raster, then in vector. so far, so good. Now, when I try to zoom some other area of the vector, it crashes and gives this msg: "WARNING: unable to open raster map [name of my VECTOR here]. and then it stops…
while executing
Any ideas?
Carlos
my hard drive.”
Markus Neteler http://mpa.itc.it
